PT Cruiser Forum Car Videos
Car Rims
How many miles?
  #11 (permalink)
Old 18 Dec 2003, 09:35 pm
sakigt sakigt is offline
Send a message via AIM to sakigt
quote:Originally posted by 3BarBoost
Mine has 8500 miles, had it since early June. Showing mysterious tire wear on fronts only - have to rotate often.
Wow I have the same problem. Must be a warranty issue
14.67 @ 94.5 <--- Self Proclaimed Fastest East Coast PT with Black wheels!!!
  #12 (permalink)
Old 18 Dec 2003, 09:43 pm
3BarBoost 3BarBoost is offline
Must be...
PT GT - Fastest damn lease car I could hope to have...
  #13 (permalink)
Old 18 Dec 2003, 10:14 pm
macster macster is offline
Send a message via AIM to macster
Got the same problem, it got worst after the installation of the Stage 1 upgrade. I thought that the addition of a CAI would help, but it's worst yet. Could it be the happening because of "blow by?"
[:I]
macster
Don\'t help me
Help the bear
Patriot Blue PTGT, Stage1, K&N Typhoon, 2.5\" Cat back exhaust, Sun Hyperground, Sun HOT INZAMA Hyper Voltage system, Adams Uppipe
  #14 (permalink)
Old 19 Dec 2003, 01:00 am
Could it be you are spinning the tires more often with the added HP?
  #15 (permalink)
Old 19 Dec 2003, 07:38 am
hyracer hyracer is offline
I think adding S1 and the Mopar BOV causes the rubber in the tires to harden and have less grip especially in the first two gears. I've also noticed reduced traction on the street and reduced ET's at the track. I'm going to make an appointment to have my local dealer replace my front tires with drag-slicks...under warranty
Deen
  #16 (permalink)
Old 19 Dec 2003, 03:17 pm
Big Al Big Al is offline
Have just about 2000 miles on mine now - purchased early August...
Clutch failed ("rivet came loose"), so I had the clutch assembly including flywheel replaced under waranty about a month ago. Took two days...
While it was there, I got the PCM replaced under the well talked about high RPM miss TSB.
Still has a slightly rough idle when hot... Maybe wires?
Planning for Stage1 or Stage2 next year...
  #17 (permalink)
Old 19 Dec 2003, 04:59 pm
yobiebs yobiebs is offline
Send a message via AIM to yobiebs
Just crossed over 15,000 miles since the end of March 2003. Only problem I've had so far is that I needed a new f-ing transmission after 11,000 miles!!! They covered it under warranty, but after letting it sit for a few days for a DC rep to come and inspect it. They were arguing that the turbo timer I had installed had something to do with the tranny going out. What a bunch of CRAP!
Since that, though, no problems.
2003 Electric Blue GT
The Philadelphia Flyer
  #18 (permalink)
Old 19 Dec 2003, 05:12 pm
divots divots is offline
Got just over 5,100 miles since Feb. Had it in the dealer's shop for a power steering belt tensioner and the TSB PCM replacement, both under warranty.
Aloha,
Mark
  #19 (permalink)
Old 19 Dec 2003, 05:56 pm
azptcruiser azptcruiser is offline
yobiebs...the problems that you experienced with your tranny may have been as a result of all the other add-ons that you have enhanced your Cruiser with. The extra weight of all of the additional items could have caused undo wear and tear. But maybe it was specifically the new head unit and better speakers causing resonance in your car that is being transferred to the transmission.
As for me, 3,000 miles yesterday. Purchased car in early October. The majority of miles are from picking up my daughter from college every other weekend and taking her back (approx. 520 miles every other weekend). Due for an oil change next week. Only problem so far is that the gear shift knob fell off!
  #20 (permalink)
Old 19 Dec 2003, 06:42 pm
AZP, you really think that just the resonance could cause a total tranny lock? When they had it at the dealer, they said that all the transmission fluid was burt and charred. That's an interesting observation. When I had polled others about this problem when it was happening, that hadn't been brought up at all....
Also, at the time, I hadn't installed the springs yet, which I would think could possibly contribute...
vB code is On
highest miles Mr.2U General Turbo Discussions 8 21 Apr 2007 05:29 pm
UGH! Code 0442, PT Cruiser 2001 LTD, 41,000 miles tvldeals General PT Cruiser Discussions 5 08 Aug 2005 12:46 am
32.9 miles per gallon driving my GT!!! Gary04GT Turbo Performance 26 25 May 2004 06:05 pm
'03 LE Cruiser for sale with 6,500 miles walstib Classifieds: For Sale/Trade 3 31 Jan 2004 08:58 pm
20k miles per year = extra precaution?? alceryes General PT Cruiser Discussions 6 18 Dec 2003 08:17 am
  MPAA | Verizon Ringtones | Loans | Dirty Dozen Brass Band | Submit article
