Rear brakes 05 GT vert help
Old 17 Apr 2011, 04:37 pm
golf55555's Avatar
Default Rear brakes 05 GT vert help
Need some help please.... I have an 05 GT vert ATX
The rear brakes are disc and got the calipers off fine, but how does the rotor come off? Feels like a spring is holding it on? And one feels like it's locked and won't turn?
E brake stuck on?
Wife called and said the car feels like the brakes are stuck, when I got it up on jack stands and got the caliper off... One of the pads was broken off from it's bracket .....
Just need some help on how to remove the rotor.... The front rotors just slide on and off.....
Please help a brotha out....
Thanks!
SOLD-----K&N FIPK CAI, MSD wires, NGK plugs
03 Dream Cruiser series 2 #1489,5sp
k&N FIPK CAI, MSD 8MM wires, NGK iridium plugs, oil catch can, AGP wastegate, Mopar BOV,Mopar Boost Gauge,Stage 1 injectors,DSP Sport tuner,VSR Anima 18" wheels, Kelly 225-40-18 tires, 3" cat delete downpipe, APS SS dual exhaust.
Now owner of a black CSRT stage 1.
Old 24 Apr 2011, 09:51 pm
Default Re: Rear brakes 05 GT vert help
I have an 05 GT vert as well. Did the brakes a while back, they just slid right off, both front and rear. Sounds to me like your ebrake is hanging it up. There's a post somewhere out here on backing off the ebrake under the center console that may help you out. Good luck with it!
Old 25 Apr 2011, 07:20 am
golf55555's Avatar
Yep! The ebrake was hold the rotor on, pads had worn a groove inside the rotor and when I released the tension on the pads they came off!
Thanks!
Old 26 Apr 2011, 03:22 am
Somebody's been either driving with the ebrake on slightly, or doing a lot of ebrake drifting. That brake really should last a lifetime. I've done some ebrake stupidity in my time, and my ebrake still looks brand new.
rear brakes jdmickies Tech & Performance Forum 2 14 Dec 2010 10:00 pm
Rear Brakes Wienerdog General PT Cruiser Discussions 5 10 May 2009 08:31 pm
2006 Custom Rear Step Pad for Vert soonercruiser PT Cruiser Convertible Forum 3 27 Jan 2009 12:19 pm
Rear Brakes wazzzzman Tech & Performance Forum 7 09 Oct 2008 04:42 pm
rear brakes robin Wheels, Tires, Suspension 2 19 Mar 2007 09:13 am
