Power Steering Belt Squeaky.
Old 30 Apr 2011, 05:40 pm
RaineMan's Avatar
Default Power Steering Belt Squeaky.
Hey all.
Since daytime temps dropped back down into the 40's my power steering belt has begun chirping. I'm figuring 3 probable causes... A: Bad belt. B: Bad pulley. C: Bad tensioner.
Any likely suspects here? I'm gonna start by replacing the belt and see if that solves the problem... if not will go from there.
Old 02 May 2011, 03:52 pm
golf55555's Avatar
Default Re: Power Steering Belt Squeaky.
Originally Posted by RaineMan View Post
Hey all.
It's normally the belt tensioner itself..... Replace it and see if it helps, there is a TSB out that says the pulleys need lined up... like they are off centerline which causes them to squeal.... hope that helps...
SOLD-----K&N FIPK CAI, MSD wires, NGK plugs
03 Dream Cruiser series 2 #1489,5sp
k&N FIPK CAI, MSD 8MM wires, NGK iridium plugs, oil catch can, AGP wastegate, Mopar BOV,Mopar Boost Gauge,Stage 1 injectors,DSP Sport tuner,VSR Anima 18" wheels, Kelly 225-40-18 tires, 3" cat delete downpipe, APS SS dual exhaust.
Now owner of a black CSRT stage 1.
Old 17 Jun 2011, 05:02 pm
onemat's Avatar
I'm having the loud squeal problem when the car starts, especially if it's damp in the morning. Is this pulley lineup the likely cause. It's sounds dreadful. Whe you say there is a TSB out, does that mean Chrysler will pay for the repair?
Thanks,
Matt
'08 Touring Edition
Pretty much untouched at this point.
Old 17 Jun 2011, 07:48 pm
Originally Posted by onemat View Post
When you say there is a TSB out, does that mean Chrysler will pay for the repair?
Thanks,
Matt
No. A TSB is a Technical Service Bulletin that the mechanics use to make repairs on a known problem. It's not a recall and Chrysler won't pay for it unless your still under warranty.
power steering belt keeps breaking need help gerryff Tech & Performance Forum 35 11 Jan 2013 01:30 pm
a/c power steering belt tensioner swanjack Tech & Performance Forum 6 13 Apr 2011 06:51 am
power steering belt karo6 Tech & Performance Forum 4 14 Apr 2010 07:52 pm
Power Steering Airconditioner belt noise macster General Turbo Discussions 3 04 Sep 2003 06:54 pm
