Battery problem?
Old 30 Apr 2011, 07:11 pm
Default Battery problem?
Hello I had a good one today. My 2004 turbo check engine light came on, cruise control shut off and would not come back on, air bag light came on, speedometer dropped to 10 miles per hour no matter what speed i was going, engine lost power and started misfireing and shut off. The battery light did NOT come on. error codes p0032, and P0038, also three codes about injectors being open. could this be a weak battery? my battery charger says it was at 50% charge. any guidence would be greatly appricated!
Thanks.
Old 30 Apr 2011, 08:53 pm
Default Re: Battery problem?
Originally Posted by raymoid View Post
Hello I had a good one today. My 2004 turbo check engine light came on, cruise control shut off and would not come back on, air bag light came on, speedometer dropped to 10 miles per hour no matter what speed i was going, engine lost power and started misfiring and shut off. The battery light did NOT come on. error codes p0032, and P0038, also three codes about injectors being open. could this be a weak battery? my battery charger says it was at 50% charge. any guidance would be greatly appreciated!
Thanks.
Welcome to the Forum!!! Take the car to a auto parts store, they will check it under load, you prolly need a new battery, 7 years is really stretching it.
Old 03 May 2011, 07:53 am
Smile Re: Battery problem?
I changed the battery and the problems went away. The wierd thing was I never had problems starting the engine.
Old 19 May 2011, 06:36 pm
I need to change to terminal battry cable, hubby won't get off the sofa, can anyone tell me how?
Old 19 May 2011, 06:37 pm
ohh 2005 turbo conv touring
Old 19 May 2011, 06:45 pm
Which side, pos or neg, or both?
Oh and...
problem with the PCM after battery replacement MrDove Tech & Performance Forum 20 04 Jun 2015 03:56 pm
Battery Change Causes Airbag Problem? Notamechanic Tech & Performance Forum 3 23 Sep 2010 04:04 pm
Alternator/battery problem jdmickies Tech & Performance Forum 2 21 May 2010 04:20 pm
Help!!!! Battery Problem JazzeCouture General PT Cruiser Discussions 3 09 Nov 2008 01:59 pm
Possible Battery Problem ? Johns Steel Blue Tech & Performance Forum 2 02 Jul 2007 08:31 am
