has anyone installed this
Old 11 May 2011, 08:54 am
Default has anyone installed this
a water injection kit
WATER / METHANOL TURBO INJECTION SYSTEM - COMPLETE KIT | eBay
Old 11 May 2011, 11:37 am
RaineMan's Avatar
Default Re: has anyone installed this
I've seen meth injection kits on several cars. They're pretty cool but it's really only a toy to use if you go to the track a lot.
Old 11 May 2011, 10:02 pm
chris15's Avatar
Yes. PTCrew is the place you want to inquire about this.
2003 GT (6262, the works)
2001 PT MTX-Swapped/Turbo
Old 20 May 2011, 11:04 am
I agree. For serious track time, I put regular old racing fuel in the tank.
Old 20 May 2011, 03:21 pm
Kawizx9r's Avatar
Not uncommon at all.
I'll be running one after my turbo upgrades are done. Just can't decide if I want to go with Devil's Own or Coolingmist.
Alot of the SRT guys run both brands with good results.
If you're thinking about meth injection, you'll need your supporting mods IE wideband (monitor a/f ratios to ensure safety/efficiency), tuning capabilities, bigger injectors (you don't want to go too lean at high boost), boost gauge (for monitoring and to check for boost leaks before anything else), 3bar MAP/TIP (if running PCM controlled wga, stock sensors don't do much with anything over 18psi), upgraded WGA (FM or S2 recommended).
Kawi is a friggin genius!
Son, installed the K&N Espresso Tech & Performance Forum 6 02 Jul 2005 11:48 pm
BOV Kit installed DREAM2 General Turbo Discussions 2 25 May 2004 12:13 am
installed BOV GTCruiser2003 General Turbo Discussions 1 11 May 2004 06:13 pm
who has installed stg 1 kit tthrift Stage Turbo Kits 12 07 Aug 2003 11:54 pm
