Spark Plugs and Wires
Old 19 May 2011, 07:21 am
StealthyK's Avatar
Default Spark Plugs and Wires
I know this has been talked about a lot as I've read a lot about this topic on this site. I just want to know what other people are using and what they think about it. I've already done this on my NA 2003 Limited PT. Now I need to do it for my turbo 2003 Dream Cruiser.
I found some NGK Iridiums for $30 and Granatelli wires for $50 on modernperformance.com. The Granatelli wires on Granatelli's site are over $100. Does anyone know why? Is this a good set up for the turbo and is this a good price?
The only upgrade I have now is a Mopar Stage 1.
Like I said above I've done this job on my NA already. What are the differences to do this job on my turbo? I've read that if you have the plastic intake you don't need to remove it. I still have an alluminum one. Do I need to remove it?
Thanks in advance.
Old 19 May 2011, 08:38 am
Default Re: Spark Plugs and Wires
Since your question is for your Turbo, I've moved your post to the Turbo section to receive answers from the guys that should know.
Old 19 May 2011, 09:32 am
No need to remove intake on a turbo - a swivel plug socket should do for the aluminum, a swivel socket and another swivel and it can be done without removing intake (I've done both - I have plastic, daughter & son-in-law have alum.)
Manufacturer sites are more expensive so they don't undercut their dealers - If you go to K&N site, their filters are more expensive there, too..
Irridium ought to last longer - I gapped using a block of wood - Tapping on the "arm" to close, hooking the arm on the edge and ppulling to widen - avoid getting near that ting center. I gapped at 0.038.
SPARK PLUGS AND WIRES? PtTurbo04 General Turbo Discussions 19 24 Apr 2013 02:22 pm
spark plugs and wires infernodreamcruiser02 Tech & Performance Forum 9 29 Apr 2011 10:06 am
just changed spark plugs with BWD wires edb Tech & Performance Forum 6 13 Sep 2010 01:46 am
Spark Plugs & wires PTPapa Tech & Performance Forum 5 07 Apr 2009 11:56 am
Going for the spark plugs & wires PTC06Peet General PT Cruiser Discussions 1 19 Feb 2009 06:44 pm
