Problem with Brakes-Need help
  • 1 Post By monkeyboyx
Old 19 May 2011, 10:45 am
Unhappy Problem with Brakes-Need help
My traction, ABS, and Brake light are on but the car does have brakes.
Brake fluid is fine and nothing is leaking. Good brake pads and rotors.
I did get a Actron CP9449 ABS scanner since my regular ODBII scanner will not communicate with ABS modules. And these are the two errors I'm getting.
LR Sensor Circuit Fault
RR Sensor Circuit Failure
I did check under the car for wire damage but could not find anything, strange thing being is why is only the rear of the car gone. I did purchase a new ABS sensor and connected it to the car and the wheel without snaking it in under the car to test. And same codes came back right after i deleted them with the new sensor. Anybody have any idea what else I could be looking for? Any help would be appreciated. Thanks
2003, Pt Cruiser GT, Auto
Old 19 May 2011, 07:30 pm
Default Re: Problem with Brakes-Need help
Anybody seen a problem like this? Yes I did search the forum before posting this. Only thing I can think of is wires are damaged behind the engine somewhere or a damaged cable under the car but it all looked fine. Going to have crawl under the car again...ahhh
Old 19 May 2011, 08:16 pm
VNT's Avatar
VNT VNT is offline
Pull the rear sensors out and clean them, maybe when you did the brake job you buggered em up.
Alsp check the wiring to the rear connectors to the ABS Sensors at the sensors and the ABS up front.
Lastly if you dont find anything I would gamble and get two new mopar rear ABS sensors.
VNT
00 Durango SLT+ 5.9 4x4
02 Grand Cherokee 4.7 4x4
05 PT GT Silver 5 Spd Conv
17 Challenger SRT A8 GoMango
18 JL Wrangler Sahara Punkn
Old 20 May 2011, 09:19 am
I had a problem with ABS sensors - when the road was wet, I'd get light, and when they dried out, light would go off. Eventually, one died, had it replaced and no grief since.
Old 20 May 2011, 10:02 am
Well I'll go through all the wires again. I did swap out one of the sensors and nothing changed, maybe I can swap out the other side and see what happens. But I still think there is something wrong with the wires. If I figure it out then will post info.
Old 05 Apr 2012, 11:51 am
Monkeyboyx, what ended up being the actual issue and proper fix for this problem?
Old 06 Apr 2012, 06:10 pm
Well I posted my response with some pictures. Something tried to eat my ABS cables and kill me. Says my response will be checked by moderator first then it should be posted. I posted four good pictures.
This connector is basically where the passenger foot would be and mounted on the frame.
loralee76 likes this.
Old 07 Apr 2012, 02:39 pm
UptownSport's Avatar
OMFG!
My bro just replaced his fuel filter ('95 PL) twice- Chipmunks!!!!
Old 10 Apr 2012, 01:25 pm
Thanks for the response. I'll try to take a look this upcoming weekend and see if I have any of the same damage, as I'm seeing the same lights on my dashboard.
I'd love it if all I had to do was re crimp some wires instead of paying a mechanic to determine what computer has failed and then to replace it (assuming it needs to be installed, programmed, and have the failed computer sent off for refurbishment as a part exchange).
Old 10 Apr 2012, 01:54 pm
Wife's FOCUS has a problem with mice. Ate the wrapping and covering of two of the injector wires. Car still runs ok, so electrical taped them up and covered that with black wire loom. Damn thing came back and started eating the wire loom. Someone said to spray everything with silicone spray (which I use anyway on other cars when going to a show, blackens and shines up everything) and low and behold, little furry devil hasn't been back. Guess it doesn't like the taste of silicone.
Tags
abs.brakes.traction
is it a balljoint problem or a wheel bearing problem? phtech Tech & Performance Forum 2 05 Mar 2011 04:33 pm
Need a little help with the brakes here jkranites Wheels, Tires, Suspension 5 15 Jul 2009 07:43 pm
brakes... superpug666 Wheels, Tires, Suspension 2 15 Jul 2009 05:08 am
New Brakes! PTmodrod Tech & Performance Forum 10 12 Apr 2008 08:30 pm
New wheels - look good, but problem with brakes lakersfan1 Wheels, Tires, Suspension 2 19 Feb 2008 07:10 am
