What can a turbo do?
Old 08 Jun 2011, 03:03 am
Default What can a turbo do?
Please help me expound more about turbo. I know that it has a good thing to offer for my car but I don't know what it is... Please tell me...
Old 08 Jun 2011, 05:32 am
Default Re: What can a turbo do?
put your hand by the exhaust of a running car and you can feel your hand being pushed away by the exhaust gases.
A turbo uses exhaust gases to spin a wheel that spins another wheel that acts as a fan to blow more air into the car's intake.
More air + some more gas = more HP.
Old 08 Jun 2011, 07:04 am
cruserdad1976's Avatar
good explanation it will give you that "SIT YOU BACK IN YOUR SEAT" best thing is to drive a non turbo and then a turbo its pretty easy to see the difference
the turbo requires synthetic oil to help with the heat and i think they require premium fuel
Old 08 Jun 2011, 07:20 am
What can a turbo do? ......It will give your car BIG "cojones"
Old 08 Jun 2011, 12:20 pm
The three things are required for combustion are air, fuel and ignition source. The more air and fuel you can ignite in an cylinder the more HP you will make. While and engine is, as they say, just a big air pump, putting a turbo on it helps it pump more air into the cylinder by pressurizing the intake. Then the injectors have to be up to putting more fuel in and then the spark plug lights it off. This is not something you want to do yourself unless you have a lot of tech skills or you will probably grenade your engine.
Old 08 Jun 2011, 12:27 pm
Only the H.O. engines "recommend" 93, but you can use lower. The standard turbos, they recommend 87 and nothing higher or lower.
Old 08 Jun 2011, 04:36 pm
In the GT you can use lower octane in a pinch, but not all of the time. The computer will not totally compensate for all knock. Been proven on a scan gauge.
Old 08 Jun 2011, 04:59 pm
I would not be lying if I said a turbo sucks, and the bigger the turbo, the more it sucks! L M A O !!! Or, maybe it blows, and the bigger the turbo the more it blows???
Old 11 Jun 2011, 02:46 pm
PtBrewzer's Avatar
04 Platinum Series Turbomania.......
Turbo stuffs Manifold srt4 stage 3 SMT6 Turbo t3t4 50 trims and more bobgt Classifieds: For Sale/Trade 1 10 May 2010 02:29 pm
Colima Pro Street Shadow Turbo VS PT Cruiser Turbo skylight PT Cruiser Videos 5 31 Dec 2008 03:21 pm
Difference btwn Turbo & Non-Turbo Wheels tom-t-rifik Turbo Wheels/Suspension/Handling 6 12 Jun 2004 11:40 am
180HP turbo lite and 215HP turbo difference. alceryes General Turbo Discussions 27 29 Dec 2003 01:57 am
Ditch the wimpy 'Turbo' insignia on your PT Turbo CraigO Exterior & Interior Styling 18 12 Aug 2003 03:07 pm
