I need some help please.
Old 16 Jun 2011, 05:31 pm
Turboguy85's Avatar
Default I need some help please.
I was driving my Pt Gt Last night, Tried to beat a light and as soon as I got thru the light, My cruiser shut off. I rolled into the parking lot thinking it was out of gas. (It was close to E). Had my brother get some gas for me. Put it at half a tank. But it wont start. I cannot figure this out. Fuses are good, Relays are good, New alternator, New starter. It just turns over but doesn't fire up. Before all this happened maybe two months ago, If you put gas in it , it wouldn't start, Just turn over, so what I figured out is if I pull the negative terminal off for 20secs. then it would fire up. It didn't do it all the time but It did do it. It never threw any codes during this...but a sign to reset it was that the fan would kick on when trying to start, even if it was cold. The fan doesn't kick on now, when trying to start. So not sure if its related. It gets pretty frustrating not having a vehicle I can fit my whole family in, So any help on this is greatly appreciated.
2.4l turbo autostick 150000mi. Thanks in advance guys.
Old 16 Jun 2011, 05:35 pm
BladeRunner's Avatar
Default Re: I need some help please.
Timing belt? That's how they act if it breaks.
Old 16 Jun 2011, 05:41 pm
Turboguy85's Avatar
wouldn't you hear something though? Like a pop or a break?
Old 16 Jun 2011, 05:56 pm
Nope, unless you were VERY unlucky and the valves hit each other, you might hear that. You listed 150K on the clock, has the timing belt ever been done that you know of? They should be replaced..along with the water pump because you're already in there @ about 90K.
Also, it wouldn't hurt to replace the belt tensioner at the same time.
Old 16 Jun 2011, 05:58 pm
Nope. Just won't start. If it wasn't a turbo I'd say to take off the cam sensor and see if it's turning when you turn the key. If the belt is broken, the cam shaft won't be turning but I think with a Turbo, there's too much stuff in the way to do that easy trick.
Old 16 Jun 2011, 06:01 pm
Hahahaha...CREWZIN..looks like I scooped ya by 2 min!!..Now we're even!
Old 16 Jun 2011, 06:07 pm
OK, you have a Turbo, how would you check to see it the belt broke?
Old 16 Jun 2011, 06:18 pm
Nope, I don't have a turbo..only a lowly LTD I was talking about we were both typing a rely at the same time..for once I typed faster!
Old 16 Jun 2011, 10:48 pm
Also note, with that many miles, it isnt healthy on fuel pump/filter to run that low on gas. Ive saw several vehicles that run out of gas, the pump then starts pumping trash, rust, etc. from the bottom of the tank where it has settled over time, and block the filter or burn out the pump.
You might have already checked this, but id make sure its getting fuel before doing anything serious.
Old 16 Jun 2011, 10:55 pm
Kawizx9r's Avatar
Camshaft as suggested above. Usually switched out at the same time with the crank sensor.
As for the timing belt, you should see part of it as if you're looking down underneath the timing belt cover/torward the torque strut.
Otherwise, take off that timing belt cover.
Kawi is a friggin genius!
