IM SO LOST !!!!LOL
Old 22 Jun 2011, 05:22 pm
Default IM SO LOST !!!!LOL
ok so I have a 2001 pt that I would like to do a swap on but I don't know what the major diff is from the GT to the just plan turbo 2.4 I can find plan 2.4's every where but the gt motors and tannys are hard to come buy so my ?? is if I build a 2.4 turbo will I be happy with it and can it with stand the same beating a gt would. But if I just buy the plan turbo 2.4 I will rebuild it from the crank up like new pistons head job and so on thanks in advance
Old 22 Jun 2011, 08:17 pm
03GTCruiser's Avatar
Default Re: IM SO LOST !!!!LOL
The 180hp turbo lite is the same exact motor as the GT But the PCM programming is different.
Sold 2003 Pt Cruiser GT Autostick. Sold
Now a slow 2009 Pontiac vibe 2.4l 5-speed.
http://www.ptcruiserlinks.com/forum/image.php?type=sigpic&userid=9656&dateline=1247691  818
227 HP and 281 TQ
new best of 14.56 1/4 mile on 7/25/12 still using the canned tune from my diablosport predator.
*Stage 1, DSP w/93 canned tune, 3" o2 housing, 3" FWDPerformance downpipe with cutout. Bwoody solid mounts. AMX1397 TTAB with K&n drop in filter and airbox mod. AMX1397 lower pipe and AMX1397 uppipe with HKS BOV
* stock nsrt rims powdercoated black, chrome pillars.
* 3 gauge pod w/ aem wideband, Autometer ultralite oil pressure and 30/30 boost, Mopar 8" sub.*
Old 22 Jun 2011, 09:06 pm
And depending on what year there are some other differences too, like fuel injectors, etc.
Old 22 Jun 2011, 09:41 pm
ok so the long block is the same in a gt and a 2.4 right? but if im going to change all of that then it would not matter because i was going to get bigger inj and so on also the car that i am looking at is a auto what trans do I need to make it a 5 speed because the one i have is a 5 speed but its an 01
Old 23 Jun 2011, 03:04 pm
As far as injectors, the 2003 GT has the smallest injectors of the turbos, but 04 and up already have the stage 1 injectors. Some people have used a Srt4 neon trans, but the GT came with a getrag.
227 HP and 281 TQ
Old 23 Jun 2011, 03:19 pm
So I'm going to do it the car is an 05 or 06 auto and there is an 05 . Five speed on eBay that came out a gt so what would I need or would the auto CPU work on the 5 speed
Old 23 Jun 2011, 04:06 pm
I think you would need a 5 speed PCM and a getrag transmision to make it work. Also you should get a 03-05 because after 06 they changed PCMs and went cambus. You should try to get a parts car so you can get everything out, like wire hardness, shift cables, axles, etc, etc
Old 23 Jun 2011, 05:17 pm
The internals are different on the turbo motor too as compared to the NA motor. Beefed up rods and oil squirters on the bottom of the pistons for cooling. Can't remember if the block has more reinforcing or not.
Old 27 Jun 2011, 09:52 pm
What's a getrag
Old 27 Jun 2011, 10:43 pm
Originally Posted by heavyhitters View Post
What's a getrag
Its a transmission manufacturer. The PT Cruiser GT uses a Getrag 288
my car lost all power PTCRZ666 Tech & Performance Forum 4 10 Jun 2010 07:16 pm
Lost 3rd. Gear kingsfan General PT Cruiser Discussions 4 04 May 2010 07:55 pm
lost all car key outdoorbloke General PT Cruiser Discussions 8 15 Dec 2007 03:02 pm
New and Lost fy9-03pt General Turbo Discussions 1 26 Apr 2003 07:02 pm
