Preventative Maintenance
Old 27 Jun 2011, 04:06 pm
TallahasseeGT's Avatar
Default Preventative Maintenance
Im swapping out my turbo this weekend, I've already done a few pre maintenance items (spark plugs & wires, air filter, Etc). I also have new synthetics, oil filter, and coolant ready to go for swap time. Question is, my car is pushing around 150,xxx. I KNOW my timing belt has never been replaced, that's a sad fact. Should I just go ahead and replace it while I'm down there? If so whats the best place to get a reasonable replacement. Should I replace anything else when doing so? (Cams, tensioners)?? I've been posting a bit latley and reading a lot trying to get prepaired for this.I want to do this, But I dont want to have to be back under the hood in 3 weeks if I can help it. What's the word, anything you think I should look @ while I'm under the hood?
2004 PT GT 5-Speed: Traded for a 2004 Mustang GT 5-Spd
2004 PT GT ATX: (Daily Driver) Airbox Mod w/ K&N Filter, Custom Intake Pipe, HKS BOV, Dejon Powerhouse UIP, Mopar Stage 1 PCM, 3 Guage Pillar Pod, Boost Guage, Oil Temp Guage, Air Fuel Ratio w Wideband, Reinforced OEM Motor Mounts, Ceramic Pads, Flameball Shifter (Ivory w/ Red Flame), Kenwood 12" w/ 800w Sony Xplod
Old 27 Jun 2011, 04:19 pm
SCBluePT's Avatar
Default Re: Preventative Maintenance
150,000 on the original timing belt!Yes,you should definately go ahead and change it.You should also change the tensioner and water pump while your at it.A lot of people on here get there timing belt kits from RockAuto Parts Catalog .You should probably go ahead and change the drive belts and hoses while you have everything apart too.
Old 27 Jun 2011, 06:33 pm
Yep, that's the way to go.
Old 27 Jun 2011, 07:08 pm
thank you
Old 28 Jun 2011, 07:35 pm
tryingbe's Avatar
What caused the failure of the previous turbo?
85 GLH
Watch out for anchor engine mounts!!
Old 28 Jun 2011, 08:36 pm
VNT's Avatar
VNT VNT is offline
Too late but I would be looking at doing the coolant feed and return lines for the turbo and new oil feed and oil return lines for the turbo and lastly the two coolant feed and return lines for the oil cooler.
The rubber sections will not last forever and when you have the turbo out, that is the time to repalce them. I did them all last year save the oil feed and return.
Note I only had 100K and my turbo is fine since I have always used synthetic.
If your turbo failed because it was coked up, you best replace them(oil lines) or you will be installing a new turbo inshort order. Ask Chris at turbos unleashed.
VNT
00 Durango SLT+ 5.9 4x4
02 Grand Cherokee 4.7 4x4
05 PT GT Silver 5 Spd Conv
17 Challenger SRT A8 GoMango
18 JL Wrangler Sahara Punkn
Old 29 Jun 2011, 06:47 am
Previous owner didnt use full synthetics....
Old 29 Jun 2011, 06:59 am
Car goes onto the lift this friday. Replacements will include:
.Timing belt and tesnioners.
.Water pump
.Thermostat
.Air filter
.Spark plugs
.Turbo (Remember that I have purchased this myself, Family Mech is just doing the swap)
.Oil in line, (Family Mech, said my other lines look fine and they could be cleaned. How do you feel on this?)
.Fog light relay (about time)
.Plus a new A/C charge, it's real hot here in the summer.
.Coolant flush and refill for the radiator and such.
.New mobil one oil filter and mobil one full synthetic oil change.
Not to mention he washes all the cars he does work on.
Subtotal cost to me: $590.00 + tax ($0.07/1.00).
Total Cost: $631.30
Old 29 Jun 2011, 07:06 am
Is that for the parts and labor? or labor only?
Old 29 Jun 2011, 03:41 pm
parts and labor.
Except for the turbo and oil line, I already have them.
Preventative Maintenance Questions..... Busa_Powered General PT Cruiser Discussions 11 26 Jun 2011 11:58 am
Car Maintenance software for OS X pegn General PT Cruiser Discussions 2 17 Feb 2011 11:13 pm
more maintenance careyk General PT Cruiser Discussions 1 22 Oct 2009 09:12 pm
Transmission Maintenance SoCalCruiser Tech & Performance Forum 11 24 Jul 2009 01:34 pm
30,000 to Maintenance To Do ? okonrad Turbo Performance 8 16 Mar 2005 02:10 am
