need advice on a cat delet
Old 01 Jul 2011, 11:18 am
mattsptgt's Avatar
Default need advice on a cat delet
OK so IV asked a few people but I need more information. My 3inch down pipe dum is going to be here today but how do I keep my car from throwing codes I have the dsp tuner but is that all I need how else do other run catless down pipes with out throwing codes
Old 01 Jul 2011, 11:21 am
RaineMan's Avatar
Default Re: need advice on a cat delet
The only "official" way to do it is to tune the ECU and delete the rear O2 sensor warning light. Other methods are hit or miss.
Old 01 Jul 2011, 01:45 pm
mattsptgt's Avatar
And how do I do that
Old 01 Jul 2011, 02:25 pm
xwing777's Avatar
Go get 2 spark plug non foulers at auto parts, drill out one (so the o2 sensor will fit all the way through, screw the second one on the end of the one you drilled. Install both onto the down pipe and install your o2 sensor.
This keeps it far enough out of the exhaust stream to trick the PCM.
Old 01 Jul 2011, 05:25 pm
mattsptgt's Avatar
IV heard of doing that before so what u mean drill it out it already comes with two holes in the pipe one for 02 and other for a wide band
Old 01 Jul 2011, 05:53 pm
xwing777's Avatar
Not the downpipe, the non fouler as the o2 sensor will hit the inside if you dont drill it deeper.
Others methods that work:
OR stage1 pcm doesnt see the sensor but it does need to be left plugged in. I got mine removed and tied up under the car. I then used the free bung hole ( ) to mount the sensor for the air/fuel gauge.
OR you can find someone that uses Diablosport CMR (tuner shop) and they can change the code to turn this off as RaineMan posted
One of the best in my area is Nigel Alexander he goes by Turbo666 on most forums email: Nigel@TruDynoSports.com and see what he would charge (he can do through email)
Old 20 Jul 2011, 12:30 pm
Send a message via MSN to niel
Or a J shaped defouler would work great... Kawizx9r told me the trick about the spark plug non fouler but I already buy the needswings defouler "J" shape and it worked fin for me for the past 3 months
"I AM THE DIGITAL SIGNAL PROSESSOR"
Need advice before I buy onemat General PT Cruiser Discussions 24 07 Aug 2010 02:52 pm
Need help...advice careyk General PT Cruiser Discussions 7 17 May 2010 01:20 pm
Need Some Advice PtCruiser04 General PT Cruiser Discussions 5 22 Apr 2010 11:10 am
Need advice air4cefamily Interior Accessories Forum 7 30 Mar 2008 01:52 am
Any advice? jsp70 General Turbo Discussions 11 02 Aug 2004 10:48 am
