A/C will cause engine to stall
Old 10 Jul 2011, 05:42 pm
Default A/C will cause engine to stall
Hey guys and gals, new to the forum and posting my first question.
When I turn on my A/C at idle while in any gear but Park or Neutral my engine will quit. While at speed this does not happen and A/C functions normally.
My high and low side pressures are good and I have already installed a new IAC valve thinking that maybe it was not opening all the way or responding too slowly. It did not make any difference.
Any idea where I can go from here?
Thanks.
Old 10 Jul 2011, 06:05 pm
SCBluePT's Avatar
Default Re: A/C will cause engine to stall
Welcome to the forum.Check your fan to make sure it is running while the air is on.If not,that is probably your problem.
Old 10 Jul 2011, 06:47 pm
might be time for a tune up, any codes comeing on
Old 10 Jul 2011, 07:53 pm
Might be the fan or tune-up but it's the computer that raises the idle to compensate for the loss of power when the compressor comes on. You might have a problem with the TPS (Throttle Position Sensor) or the IAC (Idle Air Controller) also.
Old 11 Jul 2011, 08:49 am
VNT's Avatar
VNT VNT is offline
Remove throttle body and IAC motor and give it a good clenaing. Passageway for the IAC motor is probably all carboned up and it cant respond fast enough and car stalls.
VNT
00 Durango SLT+ 5.9 4x4
02 Grand Cherokee 4.7 4x4
05 PT GT Silver 5 Spd Conv
17 Challenger SRT A8 GoMango
18 JL Wrangler Sahara Punkn
Old 11 Jul 2011, 09:54 am
Thanks everybody. No codes and fan comes on with A/C.
I do have a new IAC installed but will remove TB tomorrow and give it a good bench cleaning.
I'll let you know what happens.
Old 19 Jul 2011, 11:44 am
OK, I removed and cleaned the throttle body making sure to check IAC passage. It actually was not that bad at all.
Reinstalled with the new IAC valve and I still have the same problem.
Any other thoughts?
Old 19 Jul 2011, 12:35 pm
This is Mr. Obvious but does the comperssor make any strange sound when it is engaged like the bearings are bad? I am thinking too much drag on the engine for some reason.
Old 19 Jul 2011, 12:37 pm
I am trying to think of any other reason the computer would not compensate for the AC but am coming up empty
Old 19 Jul 2011, 05:33 pm
Nope, compressor seems to be working just fine. High and low side pressures are good and I dont hear anything that sounds like a bad compressor.
Surge/stall Badger General PT Cruiser Discussions 0 30 Mar 2011 03:39 pm
Engine stall while cold! myhotwheel Canada PT Forum 0 26 Nov 2009 01:52 pm
Can You Describe A Stall? NewPTCruiserInPA Tech & Performance Forum 13 15 Sep 2008 02:28 pm
Stall on freeway - code P00344? tezz Turbo Performance 15 13 Aug 2008 05:21 pm
Engine Stall Johns Steel Blue Tech & Performance Forum 16 19 Feb 2007 03:38 pm
