Please read and give advise
Old 15 Jul 2011, 09:36 am
Default Please read and give advise
Ok I know that we all have talked about gas milage sucking big time. However I think mine is worse then before allow me to explain.
1. I replaced factory plugs and wires with iriduim plugs and better wires.
2. Took out the airbox and did a nice intake
Issues Ive seen happening. After the change I am getting the misfire on cyl 3 warning on a occasion. Also I have a remote start and when i try to start it it cranks then wont start, on the 2nd try it will. Also when I try to start with key it sometimes wont start but on the 2nd try it will. Im kinda at a loss here. I have the High Output 2.4 in a 2005 vert. Should i go back to regular plugs? Or what other recomendations do you have.
Old 15 Jul 2011, 09:42 am
Default Re: Please read and give advise
Check gap on cyl#3, check for oil in cyl#3, and if those are fine, switch #3's wire and plug with another cyl.
Old 15 Jul 2011, 09:43 am
Did you gap them at 35-40?
Old 15 Jul 2011, 10:28 am
They were gapped to 40, I have heard on the High Output Turbos the old school copper plugs are better . Is this true
Old 15 Jul 2011, 10:49 am
cruserdad1976's Avatar
i think that the turbos do not use the iridium plugs that they are suposed to use the regular plugs
Old 15 Jul 2011, 11:13 am
I have iridiums in mine and working fine
Old 15 Jul 2011, 11:15 am
Do you still have the aluminum intake? Did you change the intake gaskets when you did the plugs?
Old 15 Jul 2011, 11:24 am
Yes i have the alum intake. Nope didnt change the gasket. Now is yours the turbo High output or the turbo lite dont know if that would make a difference.
Old 15 Jul 2011, 12:57 pm
Irridiums are fine - I have them and have them in my daughter's GT - it's platinums that should be avoided in turbos because of the way the platinum tips are bonded on.
If it were an intake gasket, you'd have a lousy idle, and why would it appear when you did plugs?
try swapping first wires, then plugs and see if it changes.
Old 15 Jul 2011, 01:16 pm
RaineMan's Avatar
General advice on boosted vehicles is to use only copper plugs. Platinum and Iridum plugs burn hotter than copper and can cause knock at high RPMs b/c the electrode is remaining hot enough to ignite the air fuel mixture without a spark.
Obviously your computer has identified cylinder 3 as the problem. I would start by checking the plug and plug wire. You might have a bad plug or the wire could have frayed while you were changing plugs.
Helpful help and advise bigbadwolph General PT Cruiser Discussions 4 13 Apr 2011 01:32 pm
Need some mechanical advise JShepherd General Turbo Discussions 11 19 Jul 2010 05:59 pm
Oil change advise pt4cec Tech & Performance Forum 6 17 Jul 2009 06:15 pm
NEED ADVISE ASAP! PTDREAM_04 Tech & Performance Forum 16 16 Mar 2004 12:41 am
Buying advise please Bryans1265 General PT Cruiser Discussions 4 07 Sep 2003 10:12 pm
