Got a problem
Old 21 Jul 2011, 08:27 am
Default Got a problem
Hello all,
I have a 2003 GT that is now in the shop. Was driving and when I accelerated heard a sound like a cat crying or wind outside blowing around your house. The sound is only there when pushing the accelerator and sounds like its coming from the engine. When I stopped at the next stoplight thick white smoke came out of my exhaust like somebody popped a smoke grenade. Then it stopped. I drove straight to the shop and they've had it since. Any ideas on what it might be? Thanks so much.
JD
Old 21 Jul 2011, 09:43 am
Default Re: Got a problem
"Thick white smoke out of the exhaust" sounds like a blown head gasket. Not as bad as it sounds but the top half of the engine has to come off. Hopefully the shop is someone you know and can trust.
Old 21 Jul 2011, 11:49 am
RaineMan's Avatar
If they've gotta replace the headgasket you might as well have the water pump and timing set done while they are in there... if you haven't already.
Old 21 Jul 2011, 02:15 pm
Chris_TurbosUnleashed's Avatar
No, you don't have the ultra rare James Bond 007 PT Cruiser Edition. A compression test would confirm the headgasket failure. Intermittent smoke and strange sound usually indicate a turbo failure though. We can help you if that's what it turns out to be. Take a look at our PT Cruiser Turbo User's Guide at the link below.
http://www.ptcruiserlinks.com/forum/...albums229.html
Call us if you need additional assistance,
Chris-TU
Chris Wright-Owner
Turbos Unleashed, Inc.
Phoenix, AZ Main Office since 1997
Vienna, Austria Europe Office Now Open!
Home of the 2 Year Warranty PT Cruiser TurboCharger
Chris@TurbosUnleashed.com
http://www.turbosunleashed.com
602-76-BOOST
602-76-26678
Old 21 Jul 2011, 02:29 pm
Thanks Chris. That's why I said "sounds like a blown head gasket". He's taken it to a shop and hopefully they will confirm exactly what it is.
Old 21 Jul 2011, 02:37 pm
No problem. Hopefully it's the least expensive one between the two.
I think this message board needs a list of repair facilities across the nation that know these cars. Too many mechanics are learning while working on these cars and this costs the customers additional $. Who should we talk to about starting that list on this message board?
Chris-TU
Chris Wright-Owner
602-76-BOOST
602-76-26678
Old 21 Jul 2011, 02:47 pm
Chris,
You've only been here since the beginning of the year and look what you've seen. Those of us that have been around awhile have seen the worst possible scenarios where private shop mechanics and dealer mechanics throw parts at a problem like the car owner had an open bank account. From a small sensor to the PCM to tearing apart the bottom end and when the problem doesn't go away, they just try something else like, Ho Hum, that didn't work, let's try something else and Oh Yea, you have to pay for it anyway.
It's amazing what owners tell us when they come to the forum.
Old 21 Jul 2011, 03:01 pm
Send a message via MSN to niel
Yes.. Chris is right... the cat or wind noise when he push it means something worse like a bad turbo shaft hitting the housing... damn... I hope you dont need to spend too much money...but if its the turbo Chris at Turbos Unleash is the way to go.
Daniel
"I AM THE DIGITAL SIGNAL PROSESSOR"
Old 27 Jul 2011, 06:15 pm
CYCLONE_06's Avatar
Send a message via AIM to CYCLONE_06 Send a message via Yahoo to CYCLONE_06
I had this happen to my old Lebaron GTS. The seal blew in the turbo. Started whining loud as a jet plane... always got the attention in my school parking lot lol... then sitting at a gas station while idling, white smoke cloud behind the car.
~CYCLONE_06
"It's been said winning isn't everything... Just not by me."
--Mark Martin
problem with my 04 GAMBIT04 General PT Cruiser Discussions 13 20 Jul 2011 11:58 am
is it a balljoint problem or a wheel bearing problem? phtech Tech & Performance Forum 2 05 Mar 2011 04:33 pm
HID Problem Stizzle Exterior Accessories Forum 3 03 Jul 2008 11:12 pm
a/c problem deez92 General Turbo Discussions 0 06 Jul 2004 11:27 pm
still having problem mo-cash General Turbo Discussions 6 10 Feb 2004 09:16 pm
