Engine mounts advice please
Old 23 Jul 2011, 07:46 pm
Send a message via MSN to niel
Smile Engine mounts advice please
Hi there... Ive read a lot of post about fail engine or motor mounts... but I really cant see too well inside the mounts to see if the rubber its all messed up... so I took a little video to read your oppinions about my engine movement... My pt was idle in park.. the R N D... N R Park so tellme what you think? its the normal movement or do I need some new ones... thanx a lot: Daniel
"I AM THE DIGITAL SIGNAL PROSESSOR"
Old 23 Jul 2011, 08:24 pm
Default Re: Engine mounts advice please
I'm no expert and I've never had to change mine but I'd say you have way too much movement. Plenty of threads around to to help you if you want to change any of them yourself.
Here's a couple, I'm sure there's more:
06 Motor Mount Replacement Save $$$
How to remove upper motor mount video
Old 23 Jul 2011, 09:57 pm
Get inserts and FTW!!!
Old 24 Jul 2011, 01:59 am
Sorry Mate Idont undertand what is and insert and the FTW?
Old 24 Jul 2011, 06:43 am
Originally Posted by niel View Post
Sorry Mate I don't understand what is and insert and the FTW?
According to Google:
For The Win
F**k The World
Free The Whales
The INSERT is the hard rubber part inside the motor mounts. Its the part that actually wears out and lets the motor shake like yours.
Broken motor mount; NOT a PT
Old 24 Jul 2011, 10:22 am
rcktpwrd's Avatar
Energy Suspension Motor mount inserts:
Energy Suspension 5.1109 Motor Mount Inserts Dodge SRT4 03-05
Joel
www.rcktpwrd.com
Old 24 Jul 2011, 01:43 pm
Smile Re: Engine mounts advice please
For The Win
F**k The World
Free The Whales
Oh!! thanks heheh... now Crewzing I was reading the forum about this in some say that sometimes the knocking or rattle is due to bad motor mounts, because of the lost of power or torque that the engine struggles and need to readjust but other say that that's not true... Other thing I saw once in a website on the ptcrew forum some performance more rigid mounts do you know if they still make them... cant find the link over there anymore
Thanks a lot Daniel
Old 24 Jul 2011, 01:53 pm
Yes, apparently the mounts from the Neon SRT4 are a lot more rigid than the PT and guys here say to use them if you never what to replace your again. Actually I think the link that rcktpwrd added to his reply to you has the SRT inserts.
Not sure of your other question but I would THINK it's true that you would loose a little torque and power if your engine is shaking that much but how much I don't know.
Old 24 Jul 2011, 02:51 pm
rcktpwrd's Avatar
I recommend the SRT-4 inserts for two reasons. first is that it is both the upper and lower inserts, the PT inserts only come for one mount. second is that they come with bolts to hold the inserts together instead of zip ties. The inserts are exactly the same shape and material for both cars...
Joel
www.rcktpwrd.com
Old 24 Jul 2011, 03:03 pm
Tank you for your help and time.... so The ones in the link would fit right in the pt? I dont need to do any mods?
Newbie - Change Engine Mounts? rothmaniac General PT Cruiser Discussions 8 07 Oct 2013 02:16 pm
engine mounts lt4supr Turbo Performance 25 05 Oct 2011 01:19 pm
Engine top cover mounts? Teknoron67 General PT Cruiser Discussions 7 17 Jul 2011 11:23 pm
engine mounts lt4supr General PT Cruiser Discussions 11 04 Jun 2008 07:56 am
Engine mounts KingKole02 Tech & Performance Forum 3 13 Jan 2005 04:04 pm
