Turbo problems...help!
Old 30 Jul 2011, 11:25 am
Default Turbo problems...help!
04 PT Cruiser Turbo (non-GT), 119,000 miles the old turbo went out, sounded like a dying cat under the hood. I bought a brand new turbo cartridge and had a local shop install it. The car ran great for all of two hours, then while at wide open throttle I here a pop. Turbo isn't working again, there's no dying cat sound just an intermitent clunk. I took it back to the shop and they're perplexed. The haven't gone back in there to look at everything, I think maybe they didn't tighten a seal or gasket? The shop of course is trying to say it's something else, but what else could it be? I'm thinking faulty install but could there be another issue that hasn't been addressed. Interestingly enough the old turbo went out under wide open throttle as well, I don't know if there's a correlation there.
Any thoughts or advice would be helpful. Thanks.
04 PT Cruiser, 2.4L turbo
Black with Chrome Rims
Old 30 Jul 2011, 11:40 am
golf55555's Avatar
Default Re: Turbo problems...help!
What did they first cartridge look like? Was it free spinning or locked up? Also, did you use the old housing? Did you/they check for cracks? Did you/they check the wastegate or flapper inside they exhaust mani? Boost leak check?
SOLD-----K&N FIPK CAI, MSD wires, NGK plugs
03 Dream Cruiser series 2 #1489,5sp
k&N FIPK CAI, MSD 8MM wires, NGK iridium plugs, oil catch can, AGP wastegate, Mopar BOV,Mopar Boost Gauge,Stage 1 injectors,DSP Sport tuner,VSR Anima 18" wheels, Kelly 225-40-18 tires, 3" cat delete downpipe, APS SS dual exhaust.
Now owner of a black CSRT stage 1.
Old 30 Jul 2011, 12:07 pm
the first cartridge was free spinning not locked up. I did use the old housing, I don't believe they checked for leaks. They replaced the exhaust manifold gasket but that's it. This isn't a place that specializes in turbos so I think they just replaced the cartridge and that was it. I'm trying to find a place in LA that knows more about turbos though. So you think there could be a leak in the housing? But wouldn't the turbo not work if that were the case? I think a boost leak check would be in order too.
Old 30 Jul 2011, 12:36 pm
golf55555's Avatar
If the first cartridge wasn't locked up, and no shaft play, then it wasn't a faulty cartridge. The exhaust gasket wouldn't cause the turbo problems. If the housing is cracked it can't build pressure. And if you have boost leaks, the pressure is all out gone. Well, the majority of it. Sounds more like the wastegate sticking open to me.
Old 30 Jul 2011, 12:58 pm
well when the first turbo went, it was really loud, then sounded like rocks being shaken in a tin can. I talked to the shop, they're saying it's a defective cartridge. They also said there were no visible cracks/leaks in the housing. When the turbo went last night there was no sound per se, just no boost at all and an intermitent cluck at idle from the turbo. Where is the wastegate located on the car? I'll tell them to check that
Old 30 Jul 2011, 01:06 pm
golf55555's Avatar
If you heard rocks, then can you take pics if the wheels that are attched to the turbo from the old cartridge? Are the fins broke? If they are, there's a good chance your housing is scared and may hit the cartridge fins and cause damage. The wastegate is mounted to the turbo housing and has a rod connected to the flapper on the exhaust manifold. The turbo builds pressure inside the engine until a specific psi when the wastage actuator releases that pressure thru the exhaust. Do a google search for stock PT cruiser wastegate. Plenty of pics on the Internet.
Old 30 Jul 2011, 01:51 pm
For sure, check the oil feed line to the turbo. A real bitch to get off, but you may find it clogged. Alternate is to disconnect the line at the Turbo, and give it a crank over with a can to catch the oil. Just takes a few seconds if that. No oil, it's the oil line.
Cheap and quick check.
Old 31 Jul 2011, 07:41 pm
Taggert_LOA's Avatar
Send a message via AIM to Taggert_LOA
the oil lines should have been changed with the turbo, if you haven't done it yet do it now before you blow this turbo.
"Every civilization finds it necessary to negotiate comprimises with it's own Values"
Old 31 Jul 2011, 10:53 pm
Send a message via MSN to niel
Chris!... Calling Chris!.....we have an emergency here... Please Chris report to the Turbo section please....
Seriously you need to stop even turning on your PT and wait for Chris from Turbos Unleash instructions, its the best way to go, and you need to give him a call he is a nice guy and can help you, and if you need some parts go with him
Daniel... Good luck
"I AM THE DIGITAL SIGNAL PROSESSOR"
Old 31 Jul 2011, 10:55 pm
Here there you go
Chris Wright-Owner
Turbos Unleashed, Inc.
Chris@TurbosUnleashed.com
602-76-BOOST
602-76-26678
PT Turbo 2.4 starting problems evgenia General Turbo Discussions 10 22 Sep 2012 10:00 am
Turbo problems... I hope 2003gt General Turbo Discussions 4 30 Jan 2011 09:21 pm
Turbo problems? PTCruisinTurbo General Turbo Discussions 29 30 Jan 2011 04:08 pm
'04 PT Turbo/GT stalling problems! pcm2a General PT Cruiser Discussions 1 01 Oct 2007 07:53 am
Major Turbo problems Iris Turbo Performance 7 04 May 2004 07:06 pm
