Overheating PT GT
Old 03 Aug 2011, 01:32 pm
Default Overheating PT GT
i bought my 03 PT GT auto with a blown timing belt. there was no coolant in the engine.
i replaced the belt and pump. rad was leaking, fan was dead. new rad, fan and thermostat. i ran fine for a day or so, but the fan is almost always on. sounds like a jet taxing for a take-off.
now the engine actually overheats and the fan never shuts off. always on high speed.
any ideas before i pull the head? i suspect the idiot used rad stop leak and the head is partially plugged up or the waterpump i installed has a bad impellar.
Old 03 Aug 2011, 10:00 pm
Default Re: Overheating PT GT
If the fan is always on, it's indicating an over-heat situation.
Remember computers are really stupid. At a certain temp, it turns the fan on. And won't shut off until that condition goes away.
So why is that condition not going away?
Coolant not moving though motor and rad?
Probably.
Sound like you're on the right track for checking for stop leak, or worse yet, pepper (as it works as stop leak when you really need it to)
Good luck
Old 03 Aug 2011, 10:56 pm
xwing777's Avatar
lol...yeah thats an old school trick an old timer showed me when i worked at a garage of his. He even said in the past (like in the the 50's) he had used oatmeal!
Old 04 Aug 2011, 01:25 pm
RaineMan's Avatar
Cracking an egg in the radiator always works too. Another old school trick they used to teach housewives in case the car overheated while they were out shopping.
Old 04 Aug 2011, 04:46 pm
TallahasseeGT's Avatar
ARE YOU FREAKING SERIOUS!?!?!
EGG in my coolant system???
You have to be pulling my leg.
2004 PT GT 5-Speed: Traded for a 2004 Mustang GT 5-Spd
2004 PT GT ATX: (Daily Driver) Airbox Mod w/ K&N Filter, Custom Intake Pipe, HKS BOV, Dejon Powerhouse UIP, Mopar Stage 1 PCM, 3 Guage Pillar Pod, Boost Guage, Oil Temp Guage, Air Fuel Ratio w Wideband, Reinforced OEM Motor Mounts, Ceramic Pads, Flameball Shifter (Ivory w/ Red Flame), Kenwood 12" w/ 800w Sony Xplod
Overheating...Please HELP Bliss General PT Cruiser Discussions 2 10 Jun 2012 12:46 pm
overheating earle Tech & Performance Forum 67 04 Oct 2010 06:49 pm
Overheating Once again!!!! thetinman General PT Cruiser Discussions 4 09 Jul 2010 04:23 pm
03 Overheating Cruisjim General PT Cruiser Discussions 16 24 Dec 2009 09:26 pm
PT OVERHEATING!!!PLEASE HELP mtlhead79 Tech & Performance Forum 11 28 May 2009 09:21 pm
