PT Cruiser Forum Car Videos
Jeep Parts | Car Rims
Need New Plugs/Wires
Old 06 Jan 2004, 02:22 pm
RobGT RobGT is offline
Default Need New Plugs/Wires
Want a performance type, for not too much $$$.
GT with 25k Miles.
Any suggestions??
Also- what should they be gapped at?
Thanks!
Old 06 Jan 2004, 02:46 pm
MX-5 MX-5 is offline
The Champion copper plug will ignite 100% of the fuel. There isn't any unburnt fuel to find hidden horsepower.
New plugs will certainly be better, but only because they don't have 30K worth of wear on them.
If unburnt fuel was getting expelled through the exhaust, you would get several trouble codes and a check engine light
The gap is .045-.055
The lower compression of the OEM turbo allows for this wider gap. If you are getting misfire codes and a check engine light, close the gap to .042
Old 06 Jan 2004, 03:22 pm
What about those denso iridiums??
Click to see my GT!
Old 06 Jan 2004, 04:57 pm
Herschel Herschel is offline
Send a message via AIM to Herschel
MX-5 Are you getting tired of repeating
yourself yet......?
Old 06 Jan 2004, 05:11 pm
IRPT IRPT is offline
Herschel, I'm sure that he is, so may I...
RobGT, read this thread...
http://www.ptcruiserlinks.com/forum/...?TOPIC_ID=5633
2002 Inferno Red PT Limited
Mercedes Wiki
Old 06 Jan 2004, 06:15 pm
I apologize if anyone is is tired of repeating themselves........
Ive read that already.
Thank You.
Click to see my GT!
Old 06 Jan 2004, 06:19 pm
Sorry MX-5, but I went with the stock heat range
Champion Plugs, Screamin Demon Coil pack
(although I guess MSD makes a similar one now)
and Magnecore wires PN#45428 for the Turbo.
Hows that? H.
Old 06 Jan 2004, 08:32 pm
COP TZER COP TZER is offline
don't bother unless you are getting a new distributor etc. Why get bigger wires to send the same spark? It kinda like putting a ten inch turbo back exhaust on, when all you really need is three
My Cruiser is slow. I love the law.
Old 06 Jan 2004, 08:50 pm
GTPT GTPT is offline
Distributor???
Old 06 Jan 2004, 09:01 pm
Cal Cruzer Cal Cruzer is offline
I don't know about the wires on the PT but most times wires are replaced with some that have a much lower reisitance than a stock wire has. Stock wires can can have 500 ohms or more and performance wires come as low as 25-50 ohms. However the wires are so short on the pt that the gain would be nominal.
vB code is On
Plugs/wires in turbomangt Turbo Performance 1 15 Oct 2004 09:49 am
Should I change my spark plugs/wires? crazie.eddie Tech & Performance Forum 8 18 Sep 2004 09:30 pm
  Car Finance | Flights | Online Loans | Industrial Directory | Mortgages
