PT Cruiser Forum Car Videos
Custom Wheels
Sudden Engine Misfire
  #11 (permalink)
Old 08 Jan 2004, 07:51 pm
LAF LAF is offline
Well I worked for HESS gas back in the day. I can tell you ALL tanks have water in them! I stuck enough tanks over my time there to know, we had a paste we would put on the stick to see how much water was in the gas. We had a limit of inches per tank and then we had to have it pumped off. Also never get gas while or right after a tanker drops a tank, it mixes the underground gets the water moving up the lines, and stirs all the silt on the bottom of the underground.
Also I think 93 octane is 93 octane in this day and age. There are only so many places refineing oil to gas. I do use Hess 93. I use Sunoco 94 in my bike. There is only one Sunoco in my area that has a hose for each grade, on a bike gettin only 3 gal gas, I dont want the hose, pipe, pump, full of the last customers grade.
The recipe for perpetual ignorance is: be satisfied with your opinions and content with your knowledge.
Elbert Hubbard (1856 - 1915)
2003 Electric Blue GT-30,000 Miles on the clock
Stage 1, Greddy Profec II B. Turbo Chargers Wastegate set to 13#. Forge Motors BOV (Blue of course). Brand AMX Intake/AirCooler Pipes/K&N Cone with Snorkel to Fender well, MSD Coil, Live Wires(Blue of course), Factory rear sway bar, KYB struts and shocks, BTG strut tower brace, Suspension Techniques 1.3\" F/R lowering springs, ATP 3” down pipe with high flow cat, BTG axle back exhaust, Rear Spoiler. Russel Brake Lines/Hawk Brake Pads/Power Slot Cyro Rotors on a four corners
Support Your Right to Arm Bears
  #12 (permalink)
Old 08 Jan 2004, 09:42 pm
bobs turbo pt bobs turbo pt is offline
i had a problem like this but my car wouldn't go over 2,500 rpms car was in "safe mode" never found problem they gave me a new car!!
  #13 (permalink)
Old 10 Jan 2004, 07:49 am
VTX1800Dave VTX1800Dave is offline
To all who have replied I want to say thanks.
I took the car into the dealer yesterday, and they were very helpful and looked at it right away. They found one sparkplug wire that was not on all the way, which was from my changing the sparkplugs the day before, and they also put new plugs in the car. But they said that apparently that was not the problem. The car has no error or fault codes even though it is running so poorly. I told them the car had a Stage 1 Kit but was acting more like a Stage -2 Kit.. LOL. Anyway they said it will take a while to unravel exactly what is the problem.
Hopefully on Monday the mystery will be solved. The dealer is doing a great job in trying to get me back on the road again.
  #14 (permalink)
Old 10 Jan 2004, 11:02 am
IRPT IRPT is offline
Good luck Dave, sounds like you got one of the good dealers.
2002 Inferno Red PT Limited
Mercedes Wiki
  #15 (permalink)
Old 14 Jan 2004, 01:21 pm
tthrift tthrift is offline
Send a message via AIM to tthrift
this is my customer and he brought his gt into my shop. i just want to tell what we did and found.
things we checked:
fuel pressure check
compression check
running compression check
leak down test
pulled valve cover to look for any valve train problems
spark plugs
coil
spark plug wires
pcm
what we found:
even after doing a fuel pressure test and the injectors held 60psi with no leakdown we pulled the fuel rail off and #1 injector was dripping. this was causing alot of extra fuel in that cyl. and the car was missing really bad.
just wanted to keep everyone up to date on this problem, it had us scratching our heads for a short time.
thanks tommy
all seems to be well now, my customer will pick up his car today
  #16 (permalink)
Old 14 Jan 2004, 01:34 pm
Way to go tthrift, I bet he'll be happy to get his PT back with the problem solved.
Mercedes Wiki
  #17 (permalink)
Old 14 Jan 2004, 05:59 pm
I just want to thank Tommy and all of his people at the five star dealership. They did a fantastic job with this one. I am very knowledgeable about cars, and it had me stumped, so it was time to let the experts look at it. I am going to purchase several new injectors to keep as spares in case this ever happens again. I still suspect the gasoling from the offbrand station as the culprit in causing the problem. One thing I can tell anyone experiencing the same symptoms, if you pull the plugs and one of them is really really wet, then go right to the injector and investigate. I had tried to solve the problem with injector cleaner and new spark plugs. Nothing was working, but plug number 1 was really wet looking, plugs two thru four were perfect. So... I hope that everyone has as great a dealership as I am lucky to have at my disposal, and someone as caring and fantstic as Tommy to help solve any mysteries.
The case of the mysterious misfire is now closed... LOL.
OH.. one other thing... I was informed with the stage 1 PCM, it will not issue error codes like the stock PCM, which is why my vehicle did not have any error or trouble codes even though it was running more like a Stage -2.
  #18 (permalink)
Old 15 Jan 2004, 05:51 pm
Big Al Big Al is offline
quote:Originally posted by tthrift
what we found:
... we pulled the fuel rail off and #1 injector was dripping. this was causing alot of extra fuel in that cyl. and the car was missing really bad.
So this car is an '03 with Stage 1, right? This means it has the stage 1 (aka '04) injectors, which technically are not covered by any DC warranty... Right?
Hmmm.
  #19 (permalink)
Old 15 Jan 2004, 08:24 pm
what we found:
Hmmm.
your statement is (technically) correct the 03 stage i kit is not covered under warranty, and the 04 injectors are covered on the 04 cars warranty.
tommy
  #20 (permalink)
Old 07 Feb 2004, 01:16 am
LAF LAF is offline
tthrift,
I wish to God I lived withing 100 miles of you because you would be my Dealer for sure!
Think you can go on the road and educate the rest of the dealers?
vB code is On
Engine Misfire mike257 General Turbo Discussions 10 23 Sep 2006 11:12 pm
Review: $2200 for a NA replacement engine PT Ctown General PT Cruiser Discussions 8 24 Jul 2006 01:08 pm
sudden engine fire in 2002 pt cruiser dagna General PT Cruiser Discussions 23 07 Jun 2004 10:53 pm
TSB 1802903: Engine Misfire PTskilla General Turbo Discussions 0 18 Aug 2003 12:13 am
  Credit Card | MPAA | Buy Anything On eBay | Debt Help | Mortgages
