PT Cruiser Forum Car Videos
Jeep Parts | Car Rims
test pipe
Old 12 Jan 2004, 01:12 am
skeeter1620 skeeter1620 is offline
Default test pipe
what is a test pipe and where do i find one
Old 12 Jan 2004, 01:21 am
GLH_TC 16V GLH_TC 16V is offline
It is a Y-pipe that goes into your exhaust system that "dumps" the exhaust right after the turbo. I've got one on my GLH that I put on just before the cat. and I uncork it when I'm at the track (and sometime on the street). It is very loud but the power and boost come on a lot quicker. I got my 2.5" test pipe/dump tube from the Grand National parts bin, but you should be able to find them almost anywhere.
***Note: on the PT Turbo you might have to dump the exhaust AFTER the cat. Not sure if the O2 sensor in the cat. will be very happy if you dump before it.
Marc
2003 PT Cruiser GT Turbo, Silver
1985 Dodge Omni GLH Turbo 16V, Black
http://connect.to/YBT
Old 12 Jan 2004, 02:31 pm
Yeah I've got some pics but I have to scan them in before I post them.
Marc
Old 12 Jan 2004, 03:44 pm
Cal Cruzer Cal Cruzer is offline
Many makers of "test pipes" make them to replace the cat portion of the exhaust. Just a teminology thing that is highly illegal.
Old 12 Jan 2004, 08:47 pm
ajoeb ajoeb is offline
In earler days they were known as (cut-outs) any muffler shop can install and or fabricate for you.
Old 12 Jan 2004, 11:23 pm
IRPT IRPT is offline
Yea, I remember 'cut outs'! [^]
2002 Inferno Red PT Limited
Mercedes Wiki
Old 13 Jan 2004, 12:31 am
Back in the day they called them "Cut Outs"
In my day they called them "Dump Tubes"
Now they call them "Test Pipes"
Tomorrow, who knows what they will call them?!?!?! Exhaust By-pass System?
Marc
Old 13 Jan 2004, 03:02 am
Rolo Rolo is offline
Send a message via AIM to Rolo
"Naturally Dissipated"
Old 13 Jan 2004, 04:03 am
2sb 2sb is offline
Test pipes and cutouts are two different things. Cutouts are Y-pipes used to bypass the exhaust. Test pipes never had a Y. They were simply a pipe to replace the catalytic converter. Since this was/is illegal, these pipes were specifically sold for "testing purposes" only.
BTW back then, here in Texas, it was illegal for a shop to replace the converter BUT it was legal for the owner to replace it himself so you could buy a "test pipe", do it yourself, and still be perfectly legal.[8D]
Old 13 Jan 2004, 08:44 am
When I was growing up we didn't use a Y-pipe for a cut out. We would weld a piece of 2" pipe with a screw on cap to the exhaust, in front of the muffler, usually were the exhaust comes off the engine and bends to go back to the muffler. When you wanted to bypass the muffler you took the cap off of the pipe, or pipes on a dual exhaust, more or less cutting out the exhaust going to the muffler, hence "Cut Outs". This was the least expensive way to do it.
The other way was to purchase the Y-type pipe mentioned above.
Mercedes Wiki
vB code is On
intake pipe for air and throttle ValAir General Turbo Discussions 4 14 Apr 2007 04:30 pm
Where to get a dyno test? kiteman3221 General Turbo Discussions 5 10 Aug 2005 12:26 am
Stage 1 passed TX emissions test JohnM Stage Turbo Kits 6 11 Jul 2005 04:55 pm
Turbo Up Pipe Mean Green Turbo Performance 5 04 Jan 2004 05:11 pm
test Gary04GT Testing 0 25 Mar 2003 04:18 pm
  Freelance Programming | Loans | Mortgage | Computer Support | Online Advertising
