Doesn't Sound Good
Old 15 Jan 2004, 11:17 pm
Default Doesn't Sound Good
Just noticed a noise at idle like a pump going out, maybe a/c or steering although the a/c is putting out cold air (Florida car) and the steering seems ok. Motor and transmission seem fine; no error messages. Anybody experience this and if so what was the culprit?
Old 15 Jan 2004, 11:19 pm
no trouble here, keep us informed !! good luck
Old 15 Jan 2004, 11:29 pm
Send a message via AIM to macster
Is it "squeak squeak squeak?"
macster
Don\'t help me
Help the bear
Patriot Blue PTGT, Stage1, K&N Typhoon, 2.5\" Cat back exhaust, Sun Hyperground, Sun HOT INZAMA Hyper Voltage system, Adams Uppipe
Old 15 Jan 2004, 11:49 pm
Definitely not a sqeak. Hard to describe, sort of intermitent compressor squaks in sync with the motor revs, at least at idle speed.
Please see Forum Guidelines regarding signature image sizing.
Old 16 Jan 2004, 01:29 am
To eliminate the A/C and Pwr steering pump you have to take the belt off of the tensioner. Which involves jacking the car up etc. Another quick way may be to spray a little WD-40 on the belts area that the squaks are coming from.
macster
Don\'t help me
Help the bear
Old 16 Jan 2004, 08:22 am
Not to be ignorant but methinks putting a lubricant on a belt might make it slip,increasing heat and wear.Maybe belt dressing?
says balsamic dressing ain't bad
Old 16 Jan 2004, 08:35 am
If its a squak, squeak or etc, it's possibly a bushing or something that's rubbing. If it's rubbing, and the WD-40 gets into the area it will allay the symthoms (sp)and point out the bad item. Plus the effects of the WD-40 will not be as determenital as the effects from the belt dressing. (as in if someone is using belt dressing or WD-40 to cure a squeak or whatever then...., but you can use something like WD-40 to locate the problem)One thing about WD-40 it will wear off and not leave very much residual residue. Either way that you go, internet trouble shooting is a reach.
macster
Don\'t help me
Help the bear
Old 16 Jan 2004, 11:21 am
If it's under warranty, let the schmoes figure it out. I dunno about you guys, but I'm not turning a wrench on mine until no-one will do it for me for free.
\"They that can give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety.\"
Benjamin Franklin, Historical Review of Pennsylvania, 1759
www.cybermopar.com
TripleJack
Old 16 Jan 2004, 04:31 pm
Wisdom speaketh!
Now about those DYNO runs. I will be looking for the results tomorrow.
macster
Don\'t help me
Help the bear
Old 16 Jan 2004, 08:54 pm
Just as mysteriously as it the noise appeared, it has disappeared. I only drove a short 2 miles to work and back today, but no noise. Go figure.
Trying to explain "the sound"... blucrsr Wheels, Tires, Suspension 12 10 Aug 2005 07:31 am
Optimum sound question stirfry Sound and Security Forum 3 12 Apr 2004 09:49 pm
Great sound with bass tube! ptmama Sound and Security Forum 7 31 Mar 2004 10:51 pm
Strange fluttering/rattling sound!? gsharrock Turbo Performance 19 21 Aug 2003 09:46 am
Chirping sound while making right and left turns ptcignaboi Tech & Performance Forum 14 19 Apr 2003 09:30 pm
