Help Intake Manifold
Old 25 Jan 2004, 05:27 pm
Default Help Intake Manifold
Hi Guys,
I am putting in a new coil and have removed the 5 front bolts on the intake manifold but can't get it lose, I did not want to disconect anything else until I have it broken lose, in case I didn't it would be easy have redy to drive to work. Any ideas?????
Thanks Red
Old 25 Jan 2004, 06:00 pm
There are 2 bolts at the back of the manifold that hold it to a bracket so you need to remove them to lift the manifold up. Loosen the clamp at the t-body and slide the boot off. support the manifold with a bungee cord.
Old 25 Jan 2004, 06:38 pm
Send a message via AIM to macster
quote:Originally posted by Turbo Red
Hi Guys,
Thanks Red
Red
FYI
macster
Don\'t help me
Help the bear
Patriot Blue PTGT, Stage1, K&N Typhoon, 2.5\" Cat back exhaust, Sun Hyperground, Sun HOT INZAMA Hyper Voltage system, Adams Uppipe
Old 25 Jan 2004, 07:21 pm
LAF LAF is offline
I thought it was said a new coil can be done WITHOUT taking the intake off. I looked at it, it should go?
The recipe for perpetual ignorance is: be satisfied with your opinions and content with your knowledge.
Elbert Hubbard (1856 - 1915)
2003 Electric Blue GT-30,000 Miles on the clock
Stage 1, Greddy Profec II B. Turbo Chargers Wastegate set to 13#. Forge Motors BOV (Blue of course). Brand AMX Intake/AirCooler Pipes/K&N Cone with Snorkel to Fender well, MSD Coil, Live Wires(Blue of course), Factory rear sway bar, KYB struts and shocks, BTG strut tower brace, Suspension Techniques 1.3\" F/R lowering springs, ATP 3 down pipe with high flow cat, BTG axle back exhaust, Rear Spoiler. Russel Brake Lines/Hawk Brake Pads/Power Slot Cyro Rotors on a four corners
Support Your Right to Arm Bears
Old 25 Jan 2004, 07:29 pm
LAF
You are right. The instructions are below.
REMOVAL - 2.4L TURBO
(1) Disconnect the negative battery cable.
(2) Remove the throttle control shield (Fig. 17).
(3) Remove the throttle cables from the throttle
body lever (Fig. 18).
(4) Remove the throttle cable bracket and relocate
(Fig. 19).
(5) Remove the spark plug cables from the ignition
coil.
(6) Unlock and disconnect the electrical connector
from the ignition coil.
(7) Remove bolts from ignition coil. Twist coil to
remove 2 of the bolts (Fig. 20) from the coil before
removing it from vehicle.
Fig. 17 THROTTLE CONTROL SHIELD
Fig. 18 THROTTLE CABLES
Fig. 19 THROTTLE CABLE BRACKET
Fig. 20 IGNITION COIL BOLT
Pull coil up (Fig. 21) and out by the throttle
body side of the intake manifold (Fig. 22).
macster
Don\'t help me
Help the bear
Old 25 Jan 2004, 10:23 pm
Faster to lift the manifold up r&r the coil and install the mainfold, 10 min. Takes longer to read the instructions.
I can do a stage I in less than 40 minutes(5speed). If I worked at a Chrysler dealer I do those all day long flat rate.
Turbo Intake Manifold mvandale Classifieds: For Sale/Trade 0 19 Jan 2006 10:18 pm
discoloration of intake manifold ptgt2point4 General Turbo Discussions 3 01 Nov 2005 01:41 pm
Torque question for intake manifold on a GT crazie.eddie Tech & Performance Forum 5 29 Oct 2004 04:00 am
polished intake manifold(( IT"S HERE)) amx1397 Turbo Performance 25 07 Jan 2004 11:35 pm
Upper/lower intake manifold gasket leak? im4gzs Tech & Performance Forum 14 03 Jan 2004 01:52 am
