High side ac service port
Like Tree2Likes
  #11 (permalink)
Old 16 Jun 2014, 08:48 pm
Default Re: High side ac service port
But your 2001 did have two ports on the lines as this picture shows and it's exactly how mine is.
  #12 (permalink)
Old 27 Jul 2014, 02:18 pm
i have a hvac/plumbing company, we charge non blended freons/ r-22 etc, threw the low side, is this freon blended??, as with the blended oils/freon is where as we charge threw the high side, and as a liquid? thanks in advance, and the picture above looks like hes charging threw the low side, the larger line of the two is how we decipher in residential/commercial, i'm sure its the same here, i know the pressures run the same as a r-22 system, 50-60 low side 120 plus high side? would love to know what Chrysler wants the superheat to be or sub-cooling, as that's the most accurate way to charge as outside temp, have alot to do with charging pressures...superheat is a home-run if anyone knows that would be great!!! I have to do a little research, i already found the saturation temps for r-134a, have a PT chart on my phone with 50 different freon blends and there saturation temp already equated just match up the pressure, than the rest of the math is simple as pie!!
2005 PT CRUISER GT
Semper Fidelis!!!
  #13 (permalink)
Old 16 Sep 2014, 09:11 pm
Originally Posted by paddywagon View Post
so I went back out and checked again because, well nobodys is pefect (despite the fact that some seem to think they are) and I have nowhere near that clear a line of site to the compressor (power steering reservoir is in the way) but after cramming my arm down there to try to move the harness for a better look I can say again there is no port. There is a sensor and a bolt that I thought may have been the cap before I got the harness out of the way, but no port.
I posted a thread about not being able to find my high pressure port on my 2003 gt turbo. Kind of sounds like the same thing as Paddywagon's. Does this mean my car also does not have a high pressure service side?
2003 PT Cruiser GT Turbo 78k miles
Purchased this summer for my daughter, front end wrecked, but just radiator, ac condenser,
  #14 (permalink)
Old 23 Jun 2018, 12:07 pm
Looked at the post and I already found the high side port. My problem is how the heck to I get my fat hands and arms in there. Tried top and bottom access. I can hear the compressor engage the fan turns on but the air is a bit warmer than it should. So I assume just need a bit of juice. Can I just run the low side of my manifold gauge and hope the high side is ok or is there a trick to getting to the high side port???
Thanks guy's
06 base wagon non turbo.
Mike
  #15 (permalink)
Old 06 Feb 2021, 06:56 pm
I know this is really old but it may help others looking for the high pressure port. This is on my 2004 turbo. Looking down at the power steering reservoir it is between the reservoir and radiator. You can also start at the low pressure port on follow the line down about 14 inches and it is next to this line. Hope this helps.
rockandroller likes this.
A/C Turbo - how can I get to the low side port? Rodscruiser General Turbo Discussions 12 07 Jul 2014 06:40 pm
High Side Pressure switch smithcruiser General PT Cruiser Discussions 4 08 Aug 2009 08:24 am
A/C Compressor High Side Switch FSUCPA General PT Cruiser Discussions 2 24 Jul 2009 04:17 pm
Aircon high side port? AlexJB General Turbo Discussions 11 23 Jun 2008 09:04 am
CAN SOMEONE show me the difference in side MOLDING and side SPEARS? BABYbluePT Exterior Accessories Forum 2 20 Dec 2007 08:06 am
