What's going on HERE???
Old 02 Feb 2004, 11:04 pm
Default What's going on HERE???
My engine now has 4300 miles on it and is running flawlessly. However, I just recently noticed some discoloration (area outlined in red) in the front "intake area" as you can see from the pictures below:
What's going on here? Is this normal? Should I just clean it off and forget about it? Is it possible that the gasket is defective and/or leaking? If so, should it be replaced or should I just leave it alone?
What do you think? Thanks.
Old 02 Feb 2004, 11:24 pm
Send a message via AIM to ptcruzin42
the runners on my plenum are discolored, looks kind of like water stains or something. My engine runs fine so I don't worry about it....kind of bothers me at car shows but that's about it.
Life dealt me a hand and I\'m bluffing hard, I\'m playing poker with a joker and some uno cards.
Old 02 Feb 2004, 11:35 pm
Send a message via AIM to sakigt
Same thing with mine...think we mentioned this before... [:I]
14.67 @ 94.5 <--- Self Proclaimed Fastest East Coast PT with Black wheels!!!
Old 03 Feb 2004, 12:17 am
I have this also.
Old 03 Feb 2004, 12:37 am
Same thing here... I think that it is just a water stain. Clean it and enjoy the boost!
Marc
2003 PT Cruiser GT Turbo, Silver
1985 Dodge Omni GLH Turbo 16V, Black
http://connect.to/YBT
Old 03 Feb 2004, 12:48 am
Mine is almost exactly like yours Gary! I have 18,000 miles on my 03! Idiots at the stealers told me it was my billet oil cap leaking vapors and I should take it off fast! I could not see how vapors would just settle on the manifold shelf!! Looks like most if not all turbos have this but I have no idea what it could be. I already had the manifold correctly torqued! No diff!
Old 03 Feb 2004, 01:15 am
What product would you suggest I use to remove this discoloration ("stain") from the engine?
Old 03 Feb 2004, 12:34 pm
[/quote]
sounds like a job for Gary (turbomangt)
R_K_GT
\'03 Electric Blue GT, silencers removed, K&N intake, Blanes Hood Struts, Emblems removed from rear hatch, Stage 1, Mopar BOV, Eibach springs, 18x8 Mille Miglia EV-R on 225/40/18 BFG g-Force T/A KDW 2, Eibach sway kit F&R, BTG Strut Bar, Chrome fuel door, custom 3\" cat-back exhaust with Magnaflow High-flow muffler, Blitz Dual Turbo Timer, Autometer Triple gauge pod, Autometer Ultra-lite with boost/vac, oil press and water temp gauges, Turbochargers.com wastegate, turboxs DSBC, Adams UCP, Dynoworks motor mounts with more to come.....
Old 03 Feb 2004, 03:09 pm
I've found that an orange (citrus) based cleaner works well for cleaning stains on bare cast aluminum. I believe the acidity in the citrus is the effective ingredient. I just picked one of the several brands out at Lowes - I think it's called The Real Deal or something silly like that. I used it successfully to detail 12 year old Corvette manifold and alternator housings that had never been detailed before. I was also told that porous wheel cleaner works, but I've not looked for it.
I haven't noticed that same staining on my GT?
Old 03 Feb 2004, 04:55 pm
I just noticed it on my GT @ 12,000 miles. I might try re-torqueing the manifold bolts but I really don't think it is an issue.
