Hood adjustment?
Old 06 Feb 2004, 10:27 pm
Default Hood adjustment?
We all have gaps in our hoods, I have seen plenty of Cruisers on the road with 1/4-1/2" gaps between the hood and fender. Has anyone tried to readjust the hood to a-line properly? the wierd thing is some cars good ok, others (like mine) have one side with a wide gap, seems to be only one side when its off. [:I]
Old 06 Feb 2004, 11:12 pm
Send a message via AIM to ptcruzin42
easy fix. open up your hood, there's 4 bolts that attach it to the hinges. Loosen one side up a little bit to where you can move the hood a little but it won't slip from the hinge, move it down if you want it closer to the fender and up if you want it farther. When you let the hood back down though be careful to make sure you have enough room to clear the fender, I almost made that mistake when installing my fiberglass hood. Just move it in increments until you get it where you want it and then don't forget to tighten the bolts back up.
Life dealt me a hand and I\'m bluffing hard, I\'m playing poker with a joker and some uno cards.
Old 07 Feb 2004, 02:06 am
Send a message via AIM to Rolo
Would the little bump-stops in the front control that as well? (hinge for rear height, rubber stops for front height)
Suncoast Creations Hood Pablo Turbo Performance 0 27 Apr 2006 10:12 am
Anyone have this hood? drdave Exterior Accessories Forum 2 17 Jan 2005 07:03 pm
Review: Keystone Single Port Hood (GHD-PT1) Beacon General PT Cruiser Discussions 18 28 Mar 2004 11:34 pm
..rear axle adjustment? earringboy Turbo Wheels/Suspension/Handling 2 03 Jan 2004 07:59 pm
cowl induction hood turbomangt Exterior Accessories Forum 4 06 Nov 2002 03:35 am
