Turbo Escape tube
Old 11 Feb 2004, 01:03 pm
Default Turbo Escape tube
I just ran across a problem with another turbo that I play with infrequently (an older 951). Seems that there is a significant problem that occurrs in WOT acceleration when the backpressure at the exhaust impeller is greater than the pressure on the compressor side. All the more reason to have as large an escape tube right off the turbo to release exhaust gasses and make the turbo as efficient as possible! If you hot rod, this could be a longevity issue that would give HP and longer life to our 2.4.[:X]
Old 11 Feb 2004, 03:45 pm
So it sounds like the replacement downpipe and highflow cat is the way to go.
Old 11 Feb 2004, 03:52 pm
Your talking about the downpipe from AMX, right? Now about the highflow CAT, just what is that, the catalist converter.? As you can see, I don't know about these things but am trying to understand. Thanks for you help.
Old 11 Feb 2004, 04:29 pm
No, I was talking about the downpipe from the turbo flange to the exhaust which has the cat attached to it just before the "cat back"
Old 15 Feb 2004, 07:54 pm
Send a message via AIM to Rolo
Exhaust Manifold --> Flex Joint --> Catalytic Converter --> Intermediate Pipe --> Muffler
Can someone fill in the diameters at each -->
replace air tube to turbo flash General Turbo Discussions 9 20 Oct 2005 02:54 pm
replace air intake tube to turbo flash Northwest PT Forum 1 01 Oct 2005 07:46 pm
2003 PT Turbo Review by AUTOTEST FILE Gary04GT General Turbo Discussions 2 12 Jul 2003 09:14 am
Chrysler to Offer New Cheaper GT Turbo skylight PT Cruiser News and Rumors 19 12 Jun 2003 02:04 pm
Main turbo tube GTPT Turbo Performance 7 08 May 2003 07:54 pm
