Raditor fan help please!
Like Tree3Likes
Old 31 Jul 2012, 11:36 am
Default Raditor fan help please!
Hey guys, I just purchased a 2003 pt cruiser 2.4 turbo gt. Im having a little bit of an issue of the car running hotter than it should be and also a check engine light for P0480 (radiator fan low speed relay). I look under the car and looks like they somehow jimmy rigged im assuming a na radiator fan because the plugs dont match and they spliced wires off the fan and ran a relay and had it on high speed on start up but i took everything off. I just ordered the turbo radiator fan but my question is does the 03 raditator fan assembly has its own relay built in ? I cannot find the relay for the check engine code i have. Also would anyone know if the na pt cruiser rad fan could cause the car to run hotter than normal on the turbo pt? difference in fan blade for better flow? thanks for the help!
Old 31 Jul 2012, 11:57 am
Default Re: Raditor fan help please!
You can look in the PDC(Poser Distribution Center) in the engine bay for the relays BUT, I was always told the fan on the Turbo models are variable and not high and low and was controlled by the computer or something else so you might not have the regular 2 relays the non-turbo cars have.
Old 31 Jul 2012, 12:01 pm
Hmm I wonder what else could cause the check engine code I have. The slots for the relays for non turbo doesnt even have pins for relays to go on
Old 31 Jul 2012, 12:03 pm
Hello,
I want to ask what is the quality of TYG cooling fan.
This is China
CHRYSLER PT CRUISER 01 02 03 04 05 RADIATOR COOLING FAN 5017407AB | eBay
Old 31 Jul 2012, 12:30 pm
None of those will work...You need to get the special fan from the dealer, only made for the 03 GTs and made by Marcedes Benz ...so you are talking $500-$700 for the fan or get one from a junk yard..
Old 31 Jul 2012, 12:44 pm
PT GT 03 Radiator Fan Solution
CREWZIN likes this.
Old 31 Jul 2012, 12:48 pm
Can someone tell me if the 03 turbo pt cruiser has relays for the low speed radiator fan or how can i fix p0480?
Old 31 Jul 2012, 12:58 pm
The code is probably because of the jury-rigged fan connection from the person who sold you the car. Once you fix the fan with the suggestion above and disconnect the battery cable (done while replacing the fan), the fault code will be erased and most likely not come back.
XtrmDC2 likes this.
Old 04 Aug 2012, 04:21 pm
Ok guys i put the right radiator fan and connected it and now i still have the check engine light code and the fan doesnt come on either
Old 04 Aug 2012, 05:40 pm
Did you disconnect the battery while installing the fan? That should clear the code(s). If you did clear the codes and the engine light came on when you started the car, you have to read the code to see what it is telling you.
What did you do to try and get the fan to come on?
