WOT Miss
Old 16 Feb 2004, 07:22 pm
Default WOT Miss
At 13K miles, I am encountering a WOT miss at higher RPMs. Using 93 octane. No mods yet (WHERE IS STAGE II!!!!!!!!!!).
Secondly, I sem to recall someone saying the single BTG CAT-back was the best dal unless you are looking for the duals look.
Help!
Old 16 Feb 2004, 08:03 pm
The BTG catback is a great exhaust for Stage 1 but is only a 2.25 and if you want Stage 2 you need a 2.5" catback exhaust. You might have the high rpm miss that there is a TSB for. Look here: http://www.ptcruiserlinks.com/forum/...=high,rpm,miss
\'05 Stone White SRT4
\'04 Graphite PT Automatic
Old 17 Feb 2004, 01:41 pm
Thanks for the link. My Dreamcruiser was built March 6, 2003 so the TSB applies. Have contacted the local 5-star, so we'll see what happens. Always helps to know the proper answer before the question is asked.
Can't believe how helpful thjis forum is........
Old 17 Feb 2004, 01:50 pm
Bob, print off the TSB and take it in, they can not refuse you.
PianT
Old 19 Feb 2004, 06:03 pm
The 5-star in Sarasota said, "no problem". PCM is ordered. I just hope I don't have to wait as long for it as we're waiting for Stage II.
Old 19 Feb 2004, 06:05 pm
Make sure that they program the pinion ratio into the new PCM or the Speedo/Odometer will not work when you pick it up.
\"They that can give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety.\"
Benjamin Franklin, Historical Review of Pennsylvania, 1759
www.cybermopar.com
TripleJack
high rpm miss 1quickpt Turbo Performance 24 17 Mar 2007 06:54 pm
idle miss and boost surge mtnbktrek General Turbo Discussions 7 02 Feb 2007 04:08 pm
miss under long and heavy throttle loads pppt03turbo General Turbo Discussions 19 26 Oct 2005 08:09 am
Can't figure it out! Engine "miss" in all gears garlin Tech & Performance Forum 2 19 Jul 2003 11:58 pm
High RPM miss Lee01 Turbo Performance 23 30 Jun 2003 08:25 pm
