what is max boost
Old 22 Feb 2004, 05:57 pm
Default what is max boost
what is the max boost that our engine and turbo can produce/handle i'm not talking "i got a 21 spike". what will it produce and hold through rpm anyone done any testing. i have a strange reason for wanting to know this. it is kind of like scott's two stage boost controler but set up more like a nos system with a throttle switch what do you guys and gals think? i have heard we are not set upto go over 18 because of the map. just woundering what the system can do with s2.
Old 25 Feb 2004, 12:06 am
If you can supply enough fuel, as to not go lean, you could get away well into the 20's maybe even 30 psi, if done right.
Check out gary donovans web site, he has messed with many fwd turbo dodge/ chrysler cars of the 80's His van or Reliant K are some good refrences, since the 2.2 and 2.5 motors very built very stout, and are similar to ours in some ways.
www.thedodgegarage.com
88 Daytona Shelby Z T-II Blue
88 Daytona Shelby Z T-II Silver T-Tops
89 Caravan ES Turbo-I
03 PT GT Turbo 41TE Autostick Electric Blue
Old 25 Feb 2004, 02:10 am
I have this set-up, but until I figure out how to get that throttle swtich mounted I'm just using a toggle (mounted in that empty spot in th emiddle of those 3 switches under the radio).
I built a hybrid electric/manual boost cotroller pre-set at 18psi, but haven't installed it yet (manual pressure sensor, elctric solenoid). It uses a hobbs type pressure switch (preset to 18psi, not adjustable, but the price was right), and a solenoid. At 18psi, the sensor opens the solenoid to WGA. We'll see how it works, but I'm excited to try it out I'm also working on a new adjustable switch (to replace the hobbs type switch) that taps into the pressure sensor for my boost guage Anyways, when I get it in we'll see if it can hold 18 to redline with the stock WGA.
2003 Electric Blue GT
- Greddy E0-1, boost and AFR guages
- Custom exhaust: no muffler, side exit.
- Replaced air box with open end cone filter.
- Stage 1
Old 27 Feb 2004, 01:08 am
Send a message via AIM to 03baggedturbo
This seems like a good post or maby make a seperate forum on this site for people doing different things to make more boost and how the engine is holding up..
Speeking of dyno my intakes and uppercharge pipes are finished on saturday there is a PT get together I am going to see if someone there wants me to dyno there car stock and with the pipes on.. Well see the outcome..
ADAM
Old 27 Feb 2004, 01:13 pm
What boost is everyone running that has a mbc? I just installed my g-valve from www.fwdperformance.com and have it set at about 13 psi. The boost almost comes on to fast, can't keep the tires under it. May have to talk to Tommy about getting those filled engine mounts. Maybe they will help.
http://www.cardomain.com/memberpage/513249
[Please see Forum Guidelines regarding signature image sizing]
03 Dream Cruiser Series 2
Homemade air intake, Custom Dual Exhaust, MOPAR BOV, MBC, Stage1. More to come!
Old 28 Feb 2004, 04:59 am
I'm running pretty much a flat 14psi to redline..
- Stage 1
Stage II for PT is here! skripo General Turbo Discussions 9 12 May 2008 09:11 pm
AGP wastegate w/o boost control strangelove Turbo Performance 13 13 Mar 2007 01:22 pm
Boost Question Mel K Turbo Performance 2 04 Apr 2004 09:27 pm
Taking control of the boost Jason_L Turbo Performance 2 03 Jan 2004 10:35 pm
20lbs of boost and no eng lite amx1397 Turbo Performance 6 21 Jun 2003 07:20 pm
