Heavy Smoking...
Old 04 Nov 2012, 12:47 pm
Default Heavy Smoking...
Ok guys i need some input here. I accquired a 2004 factory turbo cruiser that is smoking heavily. It does this the enitre time its running and gets worse under load. I have done research and it sounds like the turbo is bad. what i am wandering is if i can bypass the turbo, put a N/A manifold and downpipe on it and drive it like normal? Also if anyone has any ideas on other possible problems please let me know.
Old 04 Nov 2012, 02:37 pm
Chris_TurbosUnleashed's Avatar
Default Re: Heavy Smoking...
Turbocharged engines have a much lower compression ratio then non-turbocharged versions. Removing the turbocharger set up would only lead to driveability issues due to the difference in engine electronics. Let's try to verify if the turbocharger is the issue first. Are you experiencing smoke at cold start up also or does it take a while for the smoke to appear when you start the car first thing in the morning?
Chris-TU
Chris Wright-Owner
Turbos Unleashed, Inc.
Phoenix, AZ Main Office since 1997
Vienna, Austria Europe Office Now Open!
Home of the 2 Year Warranty PT Cruiser TurboCharger
Chris@TurbosUnleashed.com
http://www.turbosunleashed.com
602-76-BOOST
602-76-26678
Old 04 Nov 2012, 04:42 pm
UptownSport's Avatar
turbo's are usually 8.8 and N/A is 9.2??????
Not massive dif
Old 04 Nov 2012, 08:27 pm
Yes the car is doing it as soon as you start it up...
Old 05 Nov 2012, 08:20 am
Call around for a rebuilder, it may cost more to convert it than rebuild.
2001 PT Cruiser, Still a Virgin
Wife's, 2001 Chevrolet 9 passenger Suburban. EFI Live tuned by me.
The Beast: 2001 GMC 2500HD, seriously modified. Daily driven at 540rwhp, race tune of 623rwhp. Blazing a 1/4 mile in 12.19 seconds.
US Army Veteran
Old 05 Nov 2012, 06:34 pm
first pull plugs and see if there's oil on them. You can also remove oil cap and see if theres massive blowby. A compression check might tell.
For Neon guys, this would be a classic broken piston due to detonation.
IF a turbocharged engine detonates, it will break pistons.
Changing the piston isn't that expensive or difficult. Ask what flat rate is.
Obviously, this could be the turbo oil feed as well,
Old 06 Nov 2012, 02:48 am
Not massive dif
After completing a little research we determined the Chrysler 2.4 litre turbo engine has a compression ratio of 8.1:1 and the non-turbo version around 9.5:1.
It's not just the difference in compression ratio that's important though. It's mainly the ECU which controls the fuel, spark and timing curve. The camshaft profiles are also designed differently then non-turbo versions.
Chris-TU
Chris Wright-Owner
602-76-BOOST
602-76-26678
Old 06 Nov 2012, 10:46 am
Chris do you have any ideas?
Old 07 Nov 2012, 01:10 am
It's really best to just give us a call so we can go over a few things on the phone.
602-762-6678
Chris-TU
Chris Wright-Owner
602-76-BOOST
602-76-26678
Old 08 Nov 2012, 12:12 am
Ill give you a call tomorrow afternoon sometime
missing, smoking bad, no power steelwalls Tech & Performance Forum 13 21 Aug 2012 03:27 am
03 tubo smoking prefesser357 General Turbo Discussions 23 11 Apr 2012 04:50 pm
Starter Smoking Swelve Tech & Performance Forum 4 14 Jan 2011 12:04 pm
rough idle and smoking jaci321 Tech & Performance Forum 3 23 May 2010 07:32 pm
Smoking Tires are amusing PlatinumTurbo Stage Turbo Kits 9 06 Nov 2006 12:20 am
