Cheap upgrades
Old 16 Mar 2013, 11:27 am
Default Cheap upgrades
I have an 05 gt convertible automatic bone stock and I was wondering if anyone could recommend some cheap upgrades to boost performance. Also, any recommendations for a new louder exhaust? I found the stock one to be way too quiet for my liking. Thanks.
Old 16 Mar 2013, 03:08 pm
Default Re: Cheap upgrades
some folks on here just remove the muffler and add a pipe in it's place. can't get much cheaper than that! you can unbolt it right before the muffler to see if you like the sound or not.
2005 PT With Muffler Delete
Old 16 Mar 2013, 05:50 pm
vipergts's Avatar
Airbox mod~K&N drop in... 5 WHP or a tad more for 40$
E1 Turbo, 3 Bar Map~Tip, 888/1025cc Duster's Injectors, Stage 1 PCM, Composite Intake Manifold, Airbox Mod With Drop In, Ported Exhaust Manifold, Walbro 255, 3 Inch Catless, Poly Mounts, Blue Plate, DCR Oil Mod, DSP, AEM A/F, FM WGA, N2mb Electronic Boost Controller, Power Demon ATX, Duster's CMR Tune, E85 Powered, Cross Driiled Rotors, BTG Springs, Mopar Ground Effects Kit, 5K HID lights and fogs, LED Tails...3080 lbs in race trim.300WHP~345 Ft Lbs Torque @ 16PSI...Now boosting 19PSI, WHP And Torque numbers coming soon.
Old 25 Mar 2013, 04:13 pm
Thanks for the info. I changed out the air filter and put a K&N filter in. I was also looking at the cold air intakes. Would I be better off installing one of those instead of keeping the filter? Also, anything else approx. under $500 that I could do to increase the hp a bit?
Old 25 Mar 2013, 05:23 pm
Take out the back seats. That's a 100lb drop in weight right there. Cost = $.0
Old 25 Mar 2013, 10:11 pm
Chriscokid's Avatar
They don't weigh that much on a vert, do they?
[SIGPIC][/SIGPIC]2005 PT GT Vert
2004 Honda Aquatrax turbo Jetski
2006 Honda Aquatrax
1998 Dolphin 36' motor home
1949 Piper Clipper taildragger
Old 25 Mar 2013, 10:25 pm
needmoretoys's Avatar
Don't go with that. Your air box is a true cold air system, It takes the air from outsida of the engine bay. Anything else you will be sucking in hot air. Did you do the air box mod? It's easy. I just took out my silencers. I went with the muffler delete and I love the sound. A little loud when it's warming up but It sounds like a rally car to me. Look into the Diablosport tuners if you want to add some easy power. Tuners are under $500 and you will not be sorry.
Lenny
FEBRUARY CRUISER OF THE MONTH
Old 25 Mar 2013, 10:27 pm
where are you located?
Lenny
Old 26 Mar 2013, 07:02 pm
2step's Avatar
You can't get any cheaper than shortening the arm on the wastegate actuator. The point is to add a slight bit more tension. This can also be done with a bleed or adding an additional spring. Free mods like this are considered ghetto but they do work, but you have to know and understand what you're doing. A little is okay but too much tension on the WGA can put you in a world of hurt without a lot of other supporting mods to fuel and spark advance.
Without going into details of the "how to's", here's a budget guide:
First 15-20 horsepower......Free
The next 20 horsepower.....$200/$300
20/30 more horsepower.....$800/$1000
More...........................$$3000/$6000
More than that............you can't afford it
Old 27 Mar 2013, 07:15 pm
2step's Avatar
................and then there's the Stage 1 PCM upgrade for about 50+ hp. It's not exactly "cheap" at $300 to $400, but it's the best bang for the buck out there and it's a simple install anyone can do.
cheap and easy performance upgrades? dunnboy Tech & Performance Forum 16 21 Feb 2012 08:11 pm
Cheap 2008 non-turbo upgrades jon711 Tech & Performance Forum 2 07 Apr 2010 07:05 am
need help with some "CHEAP" exterior upgrades/accessories BABYbluePT Exterior Accessories Forum 29 22 Dec 2007 07:16 am
need help with some "CHEAP" interior upgrades/accessories BABYbluePT Interior Accessories Forum 29 21 Dec 2007 12:49 pm
Need more cheap upgrades SwtNLwPT Turbo Performance 1 15 Jun 2004 08:03 am
