Airbox mod vs CAI
Like Tree21Likes
Old 14 May 2013, 08:41 pm
vipergts's Avatar
Default Airbox mod vs CAI
Well I had a CAI (cone filter inside engine compartment) like many folks run...They should call it a HAI (hot air intake)....I can tell you a modded air box with a K&N drop in really makes a big differenceI can't believe the extra power and throttle response...Its not a placebo effect...I was expecting very little to nothing...Sucking in 70~80 degree air compared to 150 plus engine compartment air really does make a difference...I'm on E85 so maybe it responds differently...I bet 10 WHP between the two! No joke 4 WHP gain on airbox mod and drop in vs losing 6 WHP sucking in all of that hot engine compartment air...
needmoretoys likes this.
E1 Turbo, 3 Bar Map~Tip, 888/1025cc Duster's Injectors, Stage 1 PCM, Composite Intake Manifold, Airbox Mod With Drop In, Ported Exhaust Manifold, Walbro 255, 3 Inch Catless, Poly Mounts, Blue Plate, DCR Oil Mod, DSP, AEM A/F, FM WGA, N2mb Electronic Boost Controller, Power Demon ATX, Duster's CMR Tune, E85 Powered, Cross Driiled Rotors, BTG Springs, Mopar Ground Effects Kit, 5K HID lights and fogs, LED Tails...3080 lbs in race trim.300WHP~345 Ft Lbs Torque @ 16PSI...Now boosting 19PSI, WHP And Torque numbers coming soon.
Old 14 May 2013, 10:50 pm
Default Re: Airbox mod vs CAI
I think it is possibly the E85. Because I gained a lot of power and throttle response by putting in the K&N short ram. It was a very noticeable difference.
Old 14 May 2013, 11:01 pm
needmoretoys's Avatar
But did you do the airbox mod first? You would gain over a stock restricted air box.
Lenny
FEBRUARY CRUISER OF THE MONTH
Old 14 May 2013, 11:06 pm
No, I didn't. But I didn't lose whp. I gained power. That was my entire point.
Old 14 May 2013, 11:07 pm
over a stock box you would.
Lenny
Old 14 May 2013, 11:09 pm
Viper's point was that with most of those set ups you are pulling hot air from the engine bay. The air box mod will take air from the fender well. Unless you have the type that is closed off from the engine bay you would have done better with the mod. You now have the benifit of more air flow, but its not good cold air.
vipergts likes this.
Lenny
Old 14 May 2013, 11:11 pm
I'd rather have the short ram. It works for everyone where I'm from. I know a guy who has done both. He liked the actual intake better. It's whatever you're most comfortable with.
Old 14 May 2013, 11:12 pm
It looks much cooler. I'mnot putting it down. It does work.
Lenny
Old 14 May 2013, 11:14 pm
Oh I know. I'm not offended in any way. I understood what you meant. Not to mention I love the sound.
Old 15 May 2013, 12:07 am
Send a message via AIM to mole
stock air box with a K&N here
Mole'@DCR
2004 SRT-4 built
2005 SRT-4 mole' 16g bws setup. 380hp 444tq 11.7@122 100% stock motor/head/axles. Dsp tuned.
2003.5 MazdaSPEED Protege stock
2004 PtGT Atx BWS SETUP and a few bolt ons. stay tuned for dyno #s
Contact me for all your BWS/DCR needs..........
Airbox mod PeteyGT Turbo Performance 0 27 Apr 2012 07:20 pm
Airbox Mod UmpireBill Turbo Performance 3 28 Mar 2012 05:10 pm
MY NA airbox mod SCBluePT Tech & Performance Forum 26 03 Oct 2011 12:19 pm
WTB 06 - 10 Airbox gojeepgo Classifieds: Want To Buy 18 01 Jun 2011 09:12 am
airbox mod Walzbeer Tech & Performance Forum 3 10 Dec 2008 08:05 am
