Okay, some of you may know we bought a 2004 GT a few weeks ago to replace the 2003 N/A Limited that I totaled last month. Well, this thing is really starting to concern me.
I posted earlier about oil leaks. When we got this car checked out before we bought it, we were told, among other things, that there was an oil leak. I saw the evidence myself, but it was impossible to tell how much was actually leaking. Once we got it home, I could tell it was quite a bit. The mechanic who works for the dealer (a used car lot) we got the car from has pulled the oil cooler (another story), changed the oil filter and adapter gasket, and changed the camshaft position sensor seal. It looked like an improvement at first, but a few days later, about the same amount of oil was leaking onto my driveway overnight. He also completely removed the intake manifold (both halves) to check to see if there was any leakage at the head gasket or anywhere else up top that might have been hidden with it in place. He cleaned the engine and replaced the intake manifold, using new gaskets. Then he topped off the coolant and engine oil and sent me on my way. That was 10 days ago. I was there watching (and helping) as he removed the intake manifold and noticed when he first pulled off the top half that clean engine oil dripped out of one or more of the ports - probably less than a tablespoon - as he separated it from the bottom half. I asked him about this and he said it was normal for the turbo. QUESTION 1: Is this true, or should I be concerned? I had asked him to change the oil pan gasket but he is convinced that it is not leaking. QUESTION 2: How likely is it for the oil pan gasket to leak? There is no pressure there, so it would be a pretty slow leak, if any, right? On Saturday, I checked the engine oil level and THE STICK WAS DRY! I had to add two quarts of oil to get it back to mid-range on the dipstick. I don't know for sure what the level was after he topped up my oil 10 days ago, but we are probably talking about a quart in a week, maybe more! I don't think all of that is leaking on my driveway. Note that there is no apparent oil in the coolant nor coolant in the oil, and there is no blue smoke at the tailpipe at any time. NEXT ISSUE: The car does put out a large puff of white "smoke" when it is first started from cold that dissipates quickly. It looks like water vapor to me, nothing more. If started when the engine is warm, there is no smoke. QUESTION 3: Is this normal, or should I be concerned? Now, for the latest. I noticed a few days ago a place on my driveway that looks like black droplets were blown out of the exhaust while the car was sitting there, stationary. Saturday, I had the car further down the driveway and noticed it was doing this on acceleration. My neighbor put his hand in front of the pipe before I gave it some gas and a whole bunch of wet black stuff covered it - it was mostly water with some sort of black stuff in it. His hand cleaned up easily with regular hand soap so that confirms that it was probably water based. Note that the engine coolant level (both under the cap and in the overflow bottle) has not changed since we topped it up 10 days ago after the intake manifold was removed. Also, the humidity here in Tucson is 20-25% right now. QUESTION 4: Where is all the water vapor coming from? The car had been sitting for a while before I took it out for a test drive. I put a bottle of Heet in a full tank of gas Saturday, thinking there might be water in the tank, and we will probably run that out over the next couple of weeks. TIA for any and all comments/recommendations.
2003 PT Limited ~ Inferno Red / Taupe ~ 79610mi * RIP * 2004 PT GT ~ Inferno Red / Dark Slate ~ 132000mi Last edited by eegorr; 20 May 2013 at 02:26 pm. |
I'm going to run a compression check tomorrow. Can someone tell me how to disable the fuel injectors for the duration? Is there a fuse I can pull to do this?
2003 PT Limited ~ Inferno Red / Taupe ~ 79610mi * RIP * 2004 PT GT ~ Inferno Red / Dark Slate ~ 132000mi |
In the PDC (Power Distribution Center) that's in the engine compartment, there's the No#13 fuse and that controls the "Auto Shut Down, Fuel Pump".
![]() Quote:
I pulled the FP/ASD 20A fuse - not sure how to count, but it is the 8th fuse from the driver's side in the row closest to the firewall - this prevented the engine from turning over at all! I found the ASD relay in the diagram on the inside of the PDC lid (saw this mentioned in the service manual) and pulled that instead - the engine turned over just fine. My results: 165/165, 160/160, 165/160, 160,160 (cyls 1-4, from left - two readings each, 4-5 engine rpm per reading) Then I went back and re-tested cylinder 1 - this time I got 160/160 so I'm guessing that the small reduction from left to right was due to the engine cooling off. Compression looks good to me, but when I was removing the spark plugs I noticed that there was oil down inside the spark plug bore (outside the cylinder). Does this mean that the valve cover gasket is leaking? The spark plugs are Champion RE14MCC5 - they are definitely not new. I'm going to go ahead and replace them now and probably again later, after resolving all of the issues with this engine. Is there a better plug for this application that doesn't cost $10 apiece?
There are 4 seals on the valve cover at the plug holes. You might need to replace them. Valve cover needs to be removed. BTW, compression test was perfect!
![]() Quote:
I'm pretty happy with the results myself! I was ready to see some lower numbers, especially since the compression tester I got was a $30 Actron CP7827 from Sears. Not bad for 92,000 miles. Seems to me that if all four cylinders are that high and close together a leak down test isn't really necessary, right? Valve cover gasket and plug well seals are on the list! Now, is there some way that oil could find its way past the threads on the spark plug and into the combustion chamber? If not, why don't the wells simply fill up with oil? The last mechanic I took the car to said he doesn't work on turbos but that one or more of the oil seals might be out in our turbo and we could be losing oil that way. Does that make sense? Thanks again...
I''m not really into Turbo's myself and hopefully some of the guys up on them are/will read this and give you an answer.
![]() Quote:
http://i927.photobucket.com/albums/a...ps29bb7b2e.jpg Or talk to NitroPT and get one of these to take over the function of the pcv. I does a better job than a new one and eliminates boost loose through the pcv. You can just leave the old one in place. ![]() ![]()
![]() ![]() ![]() ![]() 03 Dream stock___________________________ 04 Touring turbo lite stock_________ 02 Touring stock_____________________ The "Three Amigos" __________________________________________________ __________________________________________________ ___________Performance, Body and Service, OEM This Is my project page. http://www.ptcruiserlinks.com/forum/...oject-1-a.html This is a great read from one of our own! Badglas badglas.blogspot.com Last edited by Busted_PT; 27 May 2013 at 09:38 pm. |
![]() Quote:
See my complete post here for details. UPDATE - 5/28 @ 8:30A: NO SMOKE on first startup this morning - that is when we have seen smoking consistently (on cold start), but recently it has been smoking to some degree pretty much whenever the car was running. I topped up the oil and will keep track of the level every morning for the next week or two. BTW, I am thinking about asking the dealer to go in and find the missing parts and get Chrysler to pay for it! I wasn't able to find any posts here where someone who had this problem actually found the parts and retrieved them from under the valve cover.
2003 PT Limited ~ Inferno Red / Taupe ~ 79610mi * RIP * 2004 PT GT ~ Inferno Red / Dark Slate ~ 132000mi Last edited by eegorr; 28 May 2013 at 11:04 am. |
Thread Tools | |
Display Modes | |
2004 PT PO301 code issues | 2004kc | General PT Cruiser Discussions | 2 | 20 Apr 2012 07:42 am |
2004 PT cruiser having engine light issues | echillie1 | General PT Cruiser Discussions | 20 | 30 Dec 2011 12:19 am |
A/C issues | HO_Turbo | Tech & Performance Forum | 6 | 07 May 2011 12:10 pm |
2004 Issues - Don't want to give the car up..but... | wndyeliza | General Turbo Discussions | 7 | 23 Sep 2010 12:30 pm |
speaker issues, wattage of stereo, door speaker replacement issues | fabes89 | General PT Cruiser Discussions | 9 | 02 Jun 2009 10:59 am |
