battery
Old 17 Mar 2004, 09:01 am
Default battery
anyone know what optima battery to use? i want yellow top but like what size, im not sure how to know which model to get
Old 17 Mar 2004, 11:22 am
OPTIMA RED TOP™ batteries, featuring SPIRALCELL TECHNOLOGY, are designed for all of your starting needs.
OPTIMA Yellow Top™ batteries, featuring SPIRALCELL TECHNOLOGY, are designed for all of your deep cycle needs.
OPTIMA Blue Top batteries, featuring SPIRALCELL TECHNOLOGY, are designed for all of your marine and RV, starting and deep cycle needs.
http://www.optimabatteries.com/products/index.asp
2002 Inferno Red PT Limited
Mercedes Wiki
Old 17 Mar 2004, 10:44 pm
I put a 75/35 red top, its not the same size and the posts are reverse... no problem though, just turn the battery around and it all works good.
here's a good site for the specs and all if you want to see that...
http://www.1st-optima-batteries.com/
I forget that this is the turbo section, I have a 2001 non turbo
[image]http://img.photobucket.com/albums/v218/Jammers99/kroozah1a.jpg[/image]
<b>Kroozin' the Bay Area since January 14th 2001</b>
<b>www.ptcsv.com PT Cruisers of Silicon Valley Homepage</b>
<b>http://p220.ezboard.com/bptcruisersofsiliconvalley - Club Bulletin Board</b>
<b>Kroozah@comcast.net</b>
Old 18 Mar 2004, 01:24 am
Kroozah, get back in the right lane!!! Ha, Ha LOL[^]
Old 19 Mar 2004, 03:16 pm
I've been through this one before:
http://www.ptcruiserlinks.com/forum/...hTerms=battery
Optima does not make a direct replacement battery for the PT. In addition, the PT requires a reversed-post or "R" model number. Simply spinning the battery 180 won't do it because the goofy cables won't reach, and *** more importantly *** one of the terminals is just way too close to the metal fender [:0]
Use my research or do your own, but be aware that the traditional notion of a simple battery r/r has become more involved.
Old 19 Mar 2004, 04:31 pm
Has anyone used one of those solar battery chargers before. Manufacturer says it will keep your battery fully charged and will extend the life of your battery. Just a thought.
link: http://www.icpsolar.com/html/plus.asp
03 Black PT GT: BTG Strut Tower Brace, BTG Rear Anti Sway Bar, Psi-Fi Control Arm Bushings, H&R Wheel Spacers, Mopar Stage 2 Coilovers, Yokohama AVS ES100, Stage 1, Uppper Charge Pipe, Mopar Plastc Manifold.
Mods On The Way: AGP Wastegate Actuator
Old 19 Mar 2004, 10:44 pm
yes, all that is true, I got the cables to reach just fine.. and sure the battery post is close to the firewall, but that issue is taken care of by getting a battery cover, so no worries there either.
Old 20 Mar 2004, 05:49 pm
I had same problem with my Daughters 97 Neon and just gave up and got a Sears Die Hard Gold for $100 installed!! I wanted the Optima like I used in my Mustang but it seemed like a lot of work and cable changing for my tastes and her car!!
PT Crusier battery dies after 5 days of no use. PT OWNER General Turbo Discussions 22 28 Jan 2009 11:51 am
Optima Battery Gear_Head General Turbo Discussions 11 09 Nov 2007 02:47 pm
battery access Hud Wilson Northwest PT Forum 1 25 Feb 2006 09:17 pm
Battery Corrosion SteelBlueGT General Turbo Discussions 9 19 May 2005 06:47 pm
Volume reduced when battery disconnected tom-t-rifik Sound and Security Forum 0 28 Jun 2004 05:25 pm
