FYI Platinum vs Copper
Old 18 Mar 2004, 11:50 am
Default FYI Platinum vs Copper
Shortly after buying my ride I wanted to
change the stock plugs to something I thought
would be better. So I went to Champion Platinums,
the colder range. Last week I decided to replce the
stock coil pack with a MSD and 8.5 wires. While at it I
also changed to NGK V-Groove Copper plugs. What a surprise I
got when I removed the platinums! In all of the years that I
have been playing with cars I have never seen a set of plugs where the insulators were burned. I guess that I should blame myself
because I new that you are supposed to run copper plugs in any
motor that is super charged or turbo powered. Evidently
platinum plugs regardless of the heat range, are too hot for the
GT's.
Phil
Old 18 Mar 2004, 01:22 pm
Yep.
That has been discussed to death.
The tiny platinum tip is designed to run hot enough for self-cleaning.
Like your oven runs hotter than normal in the self-cleaning mode.
That super hot tip can pre-ignite the fuel and cause misfires. This is amplified under forced induction.
Old 18 Mar 2004, 11:50 pm
so should i switch out my factory plugs for copper plugs?
2003 turbo dreamcruiser
Old 19 Mar 2004, 12:14 am
Cpalm1, the stock plugs are copper.
Phil
Old 19 Mar 2004, 01:49 pm
ok, thanks. i misread your first post.
Old 21 Mar 2004, 07:47 pm
I'm feeling a little disapointed, my PT at 25K still runs sweet, no misfire , not a single complaint. Usually by now I have made at least one plug change.[B)]
What are you guys seeing as the most appropriate plug change time?
Old 21 Mar 2004, 10:24 pm
dc says 30,000 or before i have seen them longer with no problems and have seen them have probles sooner than that too. i would do them at 30,000
\'03 pt gt s1 mopar bov auto patriot blue
1925 modle t pulling truck w/864hp 673ft/lb 2002 harley, 1998 zrt 600 cat
http://cpatrucks.org/members/endres.html
Bosch Platinum 2 nh11 Turbo Performance 8 19 Jul 2006 06:20 pm
question on platinum plugs for 2001 N/A comPuTer General PT Cruiser Discussions 12 09 Aug 2005 03:54 pm
Copper or platinum plugs for turbo Jimbo Tech & Performance Forum 5 29 Apr 2004 04:36 pm
platinum plugs airevac19 Tech & Performance Forum 5 21 Apr 2004 11:30 am
Platinum Plugs Not Tex Tech & Performance Forum 10 28 Jun 2002 07:12 pm
