remove silencer ???
Old 22 Mar 2004, 10:58 pm
Default remove silencer ???
Is it better to remove the silencer or leave it? Is there a test to prove the difference? If it is better to remove it, how do I remove it without breaking anything? Is this the only thing remove? I saw the test with and without the rubber and it turned out the rubber is better on then off. Thanks for the feedback.
Old 23 Mar 2004, 12:47 am
There are three silencers. One in the air box, one in the snorkel and one in the turbo to air box up pipe. The one in the air box comes out with a screwdriver and can be reinstalled later if you wish. About the only way to remove the one in the turbo to air box up pipe is to replace the up pipe. I have the AMX1397 up pipe on my GT and I am very happy with it. The snorkel can be removed but you will draw in warmer air if you remove it. I took mine off opened it up and put electrical tape over the holes. Didn't increase the flow any but changed the sound a little.
The GT seems peppier with the silencers out but some claim that the PCM will adjust for it and get you back to the same power settings after a while.
Take the white one out and try it. It is easy to take off and put back on. It is easier to get out if you pull the air box out of the car first.
Old 23 Mar 2004, 01:06 am
thanks, will give it a try.
Ride Hard, Ride Fast, but Ride Safe [8)]
http://www.cardomain.com/memberpage/529247
Old 28 Mar 2004, 10:30 am
The silencer in the pipe between the "old" air box and the turbo is still there then?
I replaced the stock filter with a cold air intake and thought that all the silencers went with the old box (and snorkle)...?
Old 28 Mar 2004, 01:47 pm
If you still have the factory intake pipe from the turbo up to the airbox (or new CAI) you still have one silencer in place. The only way to get rid of it is to replace the factory plastic pipe that comes up from the turbo. AMX1397 made the one I have. I am sure there are others but I have been pleased with Jim's.
If your CAI replaced this pipe, you are good to go.
remove silencer steve smith Stage Turbo Kits 12 06 Sep 2007 02:27 am
Air Box Silencer? PoconoPT Tech & Performance Forum 13 06 May 2006 12:55 am
Silencer Removal andym Tech & Performance Forum 8 18 Mar 2005 03:50 pm
5 speed question lip General Turbo Discussions 37 23 Apr 2004 02:30 pm
warning stickers on visors - remove 'em? PTCrew02 General PT Cruiser Discussions 9 31 Jul 2003 12:27 am
