Replaced W/P, Now Revving High/Low in Idle
Old 13 Aug 2013, 04:58 pm
Exclamation Replaced W/P, Now Revving High/Low in Idle
03 2.4L Turbo
About to Trader in, Due to Engine Mounted, gaskets, pretty bad shape.
Replaced water pump, timing has been checked, checked and checked,
Starts up and Revs really high than down, than high again, ect.
IT IS NOT, throwing out any codes.
Any suggestions?
Vacuum leak?
Thanks for looking
Andrew
Old 13 Aug 2013, 05:23 pm
randyincctx's Avatar
Lightbulb Re: Replaced W/P, Now Revving High/Low in Idle
I could possibly be a vacuum leak...But,another thing that can cause it to idle erradically like that is a worn timing belt,or camshaft lobes....But, the simplest thing may be when it was reassembled,it ended up off a tooth on the belt.....You say the timing was checked 3X,was that with a timing light?...or visually?.....Visually is the best way,and it should look exactly 100% like these photos:
Originally Posted by Busted_PT View Post
Picture of the marks when they are right. You can check the marks with only the top cover off. Run the piston to top dead center. A clean screw driver with some hash marks on it will show you exactly when it is at the top. And the marks should look just like the cams on here.
Aka:~KILLER~
Old 13 Aug 2013, 05:25 pm
Default Re: Replaced W/P, Now Revving High/Low in Idle
My guess is the vacuum leak as Randy first said. Mine did the exact same thing when one of the rubber vacuum lines from the brake booster came loose.
Old 13 Aug 2013, 05:50 pm
yep timing is good, looking for any loose lines atm
Old 13 Aug 2013, 06:01 pm
It really could be something as simple as a loose or damaged vacuum hose....I would recommend starting at the brake booster (where main vacuum supply starts) and work your way back from there....Check your hood for a full diagram of vacuum routing.
Aka:~KILLER~
Old 14 Aug 2013, 10:59 pm
There are 2 wiring harnesses you can ck. One is the harness for a Automatic Idle Control Valve and the other is for the Throttle Position Valve. Youtube has the values the wires should run at. Also possible the AICV could be bad, getting a false signal from the air temp sensor or map. When last have you sprayed out your throttle body well?
Replaced the IAC Idle air control valve? Special tool needed? worcestersauced Tech & Performance Forum 14 04 Apr 2016 01:22 pm
Motor Mounts Replaced Now Vibration at Idle falconut Tech & Performance Forum 12 15 Mar 2013 07:48 pm
High idle 2001cruising Tech & Performance Forum 17 12 Sep 2012 09:17 am
replaced timing belt but slight rough idle jimhoysa Tech & Performance Forum 5 16 May 2011 09:18 am
2003 MT High Idle Sturdevant General Turbo Discussions 6 11 Sep 2007 09:55 pm
