PT Turbo 2.4L - What Hose is This ????
Like Tree19Likes
Old 16 Aug 2013, 07:21 pm
Question PT Turbo 2.4L - What Hose is This ????
Hi Fellow PT'ers!
While doing an oil change I noticed a cracked hose under my 2003 2.4L PT Turbo Dream Series, automatic tranny. Through all my forum research and other online research I cannot figure out the name, purpose or OEM part # for this hose so I can replace it. Is it a coolant hose, power steering hose, oil cooler hose, etc?? I attached 4 pics - all of the same black hose, just different angles. The black hose runs from one of the radiators (located close the drain cock) to the turbo intake I believe and under the transmission. Although I don't think it has anything to do with the turbo intake tube since it just appears to be mounted on the outside of the tube with no direct connection into the tube. Can anyone assist me with this dilemma? You may have to enlarge the pictures to full screen to see the entire pic.
Many thanks!!!
Old 16 Aug 2013, 08:06 pm
Default Re: PT Turbo 2.4L - What Hose is This ????
That is a cooling line for the power steering.
randyincctx and Dream2PT like this.
Old 16 Aug 2013, 08:14 pm
randyincctx's Avatar
Post Re: PT Turbo 2.4L - What Hose is This ????
Power steering Hose (see diagram part #1):Hoses, 2.4L [EDV] Engine. Fits: 2003 CHRYSLER PT CRUISER GT 2.4L 4 Cyl DOHC 16V Turbo, 4-Spd. Automatic,41TE | FACTORY CHRYSLER PARTS
Aka:~KILLER~
Old 16 Aug 2013, 08:36 pm
That's expensive. Wonder why they are replacing.
Dream2PT likes this.
Old 16 Aug 2013, 08:45 pm
Wink Re: PT Turbo 2.4L - What Hose is This ????
Probably leaking @ the 'crimp-on'......If it was leaking @ the radiator side(@ clamp),I'd just cut 1-2" of if possible.(it's got 'some' give)....Otherwise,I know my local NAPA has a hose-crimping tool,and they could put the new hose on the assembly(for alot less $$)....You notice Chrysler sells it as an 'assembly'.
Aka:~KILLER~
Old 16 Aug 2013, 08:49 pm
Question Re: PT Turbo 2.4L - What Hose is This ????
Hey Dream,where exactly is the leak at....I can't tell from the pics?
Aka:~KILLER~
Old 16 Aug 2013, 08:50 pm
That's some good options there.
Old 16 Aug 2013, 08:58 pm
Thanks for the feedback thus far everyone! The crack is where the hose meets the radiator almost right at the tip (about 3/8" away from radiator near the crimp on). It didn't leak yet but I'm concerned. I wrapped electrical tape around it. Anyone know a part # for aftermarket hose rather than replace the entire assembly per OEM? The car is 10 years old so maybe I would be better off replacing the entire OEM assembly vs waiting for the hoses to fail? Thanks again!
Old 16 Aug 2013, 09:11 pm
I would do just as Randy said. Trim it and reclamp it. Not like its a transmission line. Seen these last 200k and still going.
Old 16 Aug 2013, 09:13 pm
Except not everybody has a NAPA close by,if at all......Maybe a local shop (even tractor/farm equip. repair?) if they can make hyrdraulic lines?....They might have a 'crimping-tool',and do it reasonably,and it'll always be cheaper than 'stealership'.
Tubes N' Hoses - Crimping
Aka:~KILLER~
lower turbo hose??? MicheleAshley Tech & Performance Forum 6 30 Apr 2012 06:19 pm
Turbo Intercooler pipe (hose) 767skyking Classifieds: For Sale/Trade 3 05 Sep 2011 02:21 pm
Turbo coolant hose blew-heads up! littleblueGT General Turbo Discussions 2 18 Oct 2007 08:22 pm
Turbo inlet hose Brad Vandrasik General Turbo Discussions 2 19 Aug 2003 03:56 pm
BTG Turbo intake--Blue hose nbr10 General Turbo Discussions 0 08 Aug 2003 11:47 pm
