New PT Owners...How Many Miles, Oil Leak, and Knocking
Old 31 Aug 2013, 07:10 pm
Default New PT Owners...How Many Miles, Oil Leak, and Knocking
We just bought a 2005 PT Limited at an auction, 105,000 miles. We love it so far.
1. How many miles can we expect to get out of this car (with routine maintenance)?
2. There's a small oil leak, any guesses?
3. There's a periodic knocking sound in the front end, usually driving over 35 but less than 55, and not constant. Has happened 2-3 times, on very slight inclines.
Thank you!
Old 31 Aug 2013, 07:31 pm
Default Re: New PT Owners...How Many Miles, Oil Leak, and Knocking
Routine maintenance would be replacing the timing belt and water pump pretty soon.
Old 31 Aug 2013, 09:16 pm
As Busa just stated, the timing belt is due for a change and that will be a shocker if you haven't looked into that. It runs about $1000 give or take a couple hundred and it's due NOW.
We have members that have over 200,000 miles so if you take care of it, should run a long time to come.
Can't diagnose an oil leak without more information. It might be diagnosed by the mechanic while your having the timing belt done.
Knocking sound isn't a good sign but first you have to find out if it's from the engine or some suspension part underneath.
Old 31 Aug 2013, 09:26 pm
Thank you!
The noise is most likely suspension or motor mounts. Valve cover is the most common oil leak. Pull the top cover on the belt. Look for lettering On the belt. to see if its a gates or other aftermarket belt or a Chrysler belt. If it's aftermarket your good on the timing belt. I have one cruiser with 175K new belt about 5k ago.
Tags
knock, leak, miles, oil
Oil/Fluid leak onto serpentine belts, 2003 N/A, 115,000 miles engineerrock General PT Cruiser Discussions 2 17 Nov 2012 10:43 pm
Knocking Bildam General PT Cruiser Discussions 6 20 May 2012 07:17 pm
2007 Cruiser with 33,719 miles on....already has an oil leak??? xxcutetaraxx General PT Cruiser Discussions 11 26 Mar 2011 08:32 am
knocking sound mykelzy Wheels, Tires, Suspension 6 23 Sep 2004 09:51 am
