03 turbo overheats and no ac
Old 20 Oct 2013, 07:01 pm
Default 03 turbo overheats and no ac
OK, I've read ,researched and replaced parts in an attempt to solve a over heating issue.
What I have is a 03 2.4 turbo with a 4 wire fan..
Problem1.was over heating in traffic but OK while driving and ac worked..replaced fan with new , then the fan ran on super low (barley even turning) all the time and would not turn off '
Replaced new fan with another new fan.,this time the fan didn't work at all and then the ac stopped working..I found that the discharge and liquid ac lines had leaks....I have since replaced the ac lines, fan (again),ect sensor,thermostate, recharged ac,
I have checked the plug at the hardness,..I have 12v @the violet/red wire, I have 12v plus at the d/g-orange wire while running . the blue wire reads nothing
I'm thinking since the blue wire is .05 v ref that since it didn't read anything that it may be the cuas.
I guess I'm asking if there is anything I may have over looked that would cause the fan not to work at all..
After replacing the ac lines and charging the system the compressed still cycles on and off .I know these two systems overlap each other and until I get the fan going I may not have ac..
Any input would be helpful , thanks
Old 19 Nov 2013, 07:47 pm
Default Re: 03 turbo overheats and no ac
I'm new to PT problems, but I've picked up on a number of tips concerning the cooling problems. What kind of fan did you replace the OEM with? Aftermarket or Genuine Bosch-Mopar? Got a variable speed fan or a two speed? And as for coolant itself, I've found that there is an air bleeder valve on the system to get all the air out. Just popping the cap on the radiator and filling to the brim won't fill the system. Cars with radiators lower than the uppermost part of the motor's cooling design have this air bleeder, usually on top of the motor. Need to use a length of plastic hose on the bleeder to get the overflow coolant away from the top of the motor.
Old 19 Nov 2013, 08:06 pm
randyincctx's Avatar
Lightbulb Re: 03 turbo overheats and no ac
That's why alot of people have removed the 'jiggle-valve' from the thermostat & then drilled the hole out with 3/16 drill bit.......Helps with filling & removing air from the system.
Aka:~KILLER~
So cruiser overheats when AC is on. invidious General PT Cruiser Discussions 11 23 Jul 2012 09:33 pm
2001 PT overheats, HG okay packergolf Tech & Performance Forum 10 03 Jul 2012 08:50 pm
Car Still Overheats VroomMaster Tech & Performance Forum 36 30 Aug 2011 10:51 am
When AC is on PT overheats. Also looking for PT mechanic in NYC Marcos Northeast PT Forum 5 02 Jul 2011 06:29 pm
05 PT overheats when idle sponge9012 Tech & Performance Forum 26 04 Feb 2009 01:33 pm
