Code P0300 won't crank
Old 12 Dec 2013, 07:12 pm
Default Code P0300 won't crank
Hi, I have a 2005 Turbo, started running ruff on the way to work the service light came on, had to pull over, turned it off and it wouldn't crank back up. Had it towed home, got the error code P0300 checked to see if all four coils fire and they do, checked to see if gas was coming through the line, it is with plenty of pressure. It acts like it wants to crank, but sounds like it is out of gas, but I have half a tank of gas. Any suggestions would be great. Thanks.
Tags
won't start
code p0300 means ?? bobs turbo pt Tech & Performance Forum 16 27 Feb 2015 09:49 pm
Fault code P0300 Royston1973 General PT Cruiser Discussions 9 24 Nov 2011 05:55 pm
Error code P0300 & P0304 Jimpote03 Tech & Performance Forum 1 07 Mar 2011 05:28 pm
error code ques-... got a p0300- random misfire... batta Tech & Performance Forum 4 18 Apr 2010 03:26 pm
Code P0300 rszappa1 Tech & Performance Forum 2 30 Nov 2005 12:47 pm
