Wow have not been on here for awhile
Like Tree2Likes
Old 16 Dec 2013, 12:49 am
Sparkypt's Avatar
Default Wow have not been on here for awhile
Now driving a 03 gt with 113000 . auto .
Having some problems with the fan . Low speed seems to have burnt out on me and its the rare bosch mercedes motor . Anyone have a fix yet for this ? Also what would be a good aftermarket kit to add on rather than listen to the jet plane motor all the time ..
Also picked up a srt 4 exhaust . Mid pipe will not fit around rear suspension .
Ive read a few time of owners installing this swap .
I know the rear tire has to be removed . But dose anyone have any good pics of the install and what route they took?
Thanks!!!
2003 Pt GT. Black , Dumped exhaust after cat , Mopar BOV , 12 IN air intake , Tinted taillights , Debadged , Sumitomo racing tires .
Old 16 Dec 2013, 05:41 am
Default Re: Wow have not been on here for awhile
Welcome back to the forum.
Your doesn't have two speeds. The Turbo models (if I'm correct) don't have the high and low speed relays. It's a variable speed fan run by the PCM and yes, very un-common because it was the first year Turbo and pretty expensive to replace.
If your good with messing around with electrics, you can try pulling the motor apart and it should have the same brushes (that wear out) in it that the Non-Turbo model has. These can be replaced. Several owners on non-turbo PT's have done the swap but most just replace the whole fan because it's pretty cheap ($100) with the shroud.
Old 16 Dec 2013, 12:10 pm
2step's Avatar
Cool photos! That example looks like the brushes wore very unevenly. Great suggestion but I'm wondering where just the brushes alone could be bought?? I don't have a lot of faith in the dealer or Chrysler stocking them.
I vaguely recall possible PCM problems causing fan speed problems. I don't remember if there is a suggested fix like a simple battery disconnect or not. Maybe a search could turn up some details???
Old 16 Dec 2013, 12:29 pm
I sited this post quite awhile back as being the best long term, highest quality fix when the 2003 turbo radiator fan fails. The 2003 turbo fan is the only year with a constantly variable speed fan. It's speed is controlled entirely by the PCM. The highest quality fix is to purchase a new motor that is listed in the post below and install it on your old fan assembly. If you want to go searching through the salvage yards you can probably find a good used fan motor.
The post below is clear on the whole process. Please read the thread before asking any questions.
PT GT 03 Radiator Fan Solution
Jerry
Old 16 Dec 2013, 01:08 pm
Sparkypt's Avatar
Yeah finding a 211 fan motor ive found to be almost im possible .
As fars as gt cruiser .... Im like one of the only ive seen in a loong time. Rest are turbo lites and na's.
Old 16 Dec 2013, 01:13 pm
Sparkypt's Avatar
Oh one more thing on the fan issue.
I get code p0480.
Could this Help any with telling why the fan is acting up?
Or is that just telling me somthing is wrong with my fan but nenernener your chrysler wont tell ?
Old 16 Dec 2013, 01:24 pm
Sparkypt's Avatar
Oh wow , i was not aware i could replace the internal components.
As for a w211 fan motor , im in arizona and you would think i could find the mercedes part ... nope !
And yes i ment varible speed .
Anyone have anything for the exhaust problems
Old 16 Dec 2013, 02:13 pm
Thanks!!!
I've seen several pics of installs over the years and they all simply used ONLY the axle-back portion of the SRT-4 exhaust on their PTs. They removed their existing muffler and had a good exhaust shop weld in the axle-back portion of the SRT duals onto the origional PT pipe. It joins over the top of rear axle. To me the SRT goes through to many contortions to make it viable as a choice for my own PT. To much unneeded weight and flow restrictions (direction changes) to suit my taste. I simply made up my own system from the axle back out of stock pipe and a couple resonators.
STOCK SRT-4 SYSTEM and A SIDE EXIT STYLE
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Resonators and re-customized custom TYC back-up lights. Red in back-up lights changed to match the shape of the resonated exhaust tips.
[IMG][/IMG]
[IMG][/IMG]
Four inch retro turndowns
[IMG][/IMG]
Jerry
ROCKETMAN8060 likes this.
Old 16 Dec 2013, 05:43 pm
Sparkypt's Avatar
First : Nice pt jerry , thing is sweet and unique !
Yeah never thought about using the factory mid pipe ..... kinda got rid of mine !
Welp looks like im just going to sell this to some one with a srt4 or neon i suppose .
Might as well just do a 3inch turbo back !
wwpptc likes this.
Old 16 Dec 2013, 06:45 pm
Sparky, thanks for the kind words! Members here like Crewzin and Busted, know that it has taken a LONG time to get it to this point.
Sorry you got rid of the stock system, but I would have probably done the same thing if I was in your place and had expected the SRT system to just bolt in place.
Jerry
Been gone awhile sonocativo Testing 170 04 Jan 2015 09:52 am
Hope that is it for awhile$$$$$$$$ careyk General PT Cruiser Discussions 5 20 May 2010 05:37 pm
