error codes turbo
Old 02 Feb 2014, 04:58 pm
Default error codes turbo
My turbo went out on my 2005 pt cruiser convetible with standard turbo.
I had my turbo replaced and also my oil pump as it went out as a result of turbo blowing.
car runs good now
however, i get an intermittent check engine light with codes 1188 and 234.
After I reset light, it goes away for 3-5 miles then comes back on.
Any advice?????
Old 02 Feb 2014, 09:07 pm
Default Re: error codes turbo
2003 Turbo Pt Cruiser, Check engine light on, code P1188? - Yahoo Answers
https://www.google.com/#q=P0234+PT+Cruiser
Check your vacuum lines.
1999 Dodge Neon Coupe. DOHC 5 speed
2005 Crossfire SRT-6
2005 PT Cruiser GT 5 speed. 1 of 21 (SOLD)
Old 05 Feb 2014, 03:27 pm
dougs's Avatar
found this on a porsche page..
02 Turbo... Identified a "0234" fault code today = "Turbo - Super Charger Overboost condition".
The car runs good without hesitation upon acceleration and no odd behaviour.
I did have a CEL diagnosed by the dealer as 0491 and 0492 relating to SAI system but I'm not sure if the two are related, any ideas what I might be up against?
Online search reveals the following...
OBD Code P0234refers to
The PCM disables (bypasses) the supercharger boost and sets a diagnostic trouble code (DTC) to keep from damaging the powertrain (engine or transmission) during potential harmful operating conditions.
Symptoms
Possible sumptoms of OBD code P0234
- Engine Light ON (or Service Engine Soon Warning Light)
Causes
Possible causes of OBD code P0234
- Brake torque (brake on and throttle at wide open). - Transmission oil temperature (TOT) exceeds calibrated threshold. - Engine over temperature. - Ignition misfire exceeds the calibrated threshold. - Knock sensor (KS) failure
Possible Solutions
Check for other diagnostic trouble codes accompanying P0234, or check appropriate and available PIDs related to the above possible causes.
Error codes: Luvour04ptgt Turbo Performance 3 25 Aug 2013 09:16 pm
Error Codes Error lilcruiser Tech & Performance Forum 2 10 May 2012 05:34 am
05 PT Turbo error codes: 0031,0037, 0456, 2074 acuevas PT Cruiser Convertible Forum 10 08 Nov 2010 07:01 pm
PT GT Turbo crapped out, 7 error codes cbohlson General Turbo Discussions 11 28 Feb 2010 08:10 pm
