70mm throttle body
Like Tree5Likes
Old 03 Mar 2014, 01:13 pm
WPTF's Avatar
Default 70mm throttle body
has anyone tryed to retrofit one of these on our cars?
I have seen ported srt4 throttle bodies used on our cars, so this should be doable right?
BOOMBA 70mm TB
Boomba 70mm Throttle Body - Darrell Cox Racing - (Powered by CubeCart)
[/SIZE][/I]06 PT CRUISER LIMITED TURBO LITE
Custom 2.5" catback, Custom BloxRacing intake with Velocity stack, Stg1..ish Custom Tune, NGK 2315's, UltrGuage, TeinS springs, Poly inserts in motor mounts, Gutted cat, lots more to come!!!!
Old 03 Mar 2014, 01:32 pm
Default Re: 70mm throttle body
Your ITM would be the restriction being smaller then the TB.
go here and look up Nitro PT Aluminum Intake Manifold. It may help you better understand what I mentioned?
http://ptcruisernetwork.com/forum/index.php
Old 03 Mar 2014, 01:33 pm
BOOMBA 70mm TB
This seem like putting a bigger drain plug in the sink. But when I pull it I'm still stuck with the same size drain pipe. So the water still takes the same time to get out. Just my thoughts.
Old 03 Mar 2014, 01:39 pm
WPTF's Avatar
I planned on port matching my intake manifold to match since i have a spare manifold im willing to try something different and hopefully it will work so we will have a new option intead of a ported stock throttle body thats still less than 60mm.
when i get home i will measure the throttle boddy port on the intake and make sure there is enough material there to make it even possible.
Old 03 Mar 2014, 01:48 pm
I think you should go look at the thread I suggested.
It is more then a simple enlargement by means of port matching. You will still have a restriction that will be greater then the TB you are planning to use.
Cleaning up the interior and smoothing out the casting, match porting to the head and more attention to your lower ITM will have a greater benefits and using along with the porting work no more then a 55mmTB .
You also need to remember that at some point you will need to do PCM calibration for the increased WOT flow.
Old 03 Mar 2014, 02:11 pm
Random ITM pictures.....
Old 03 Mar 2014, 02:51 pm
He should have a plastic intake. So that would end that.
Old 03 Mar 2014, 03:04 pm
Old 03 Mar 2014, 03:18 pm
I wouldn't necessarily say that Danny...hey nothing a little duct tape can't make happen?
Busted_PT likes this.
Old 03 Mar 2014, 03:29 pm
WPTF's Avatar
no reason to waste the time or resources then from what your saying. oh well just a simple (what if) question. quess i will just be a lemming and get a ported stock throttle body.
Bad throttle body? phraxion Tech & Performance Forum 6 24 Nov 2013 03:34 pm
Throttle Body Jimmy2011 Turbo Performance 4 27 May 2012 06:29 pm
EGR and Throttle body pteezer129 Tech & Performance Forum 5 22 Jul 2011 02:28 pm
Throttle Body wiky86 Tech & Performance Forum 10 21 Jul 2008 09:59 pm
looking for a throttle body....................... rockrtboy Classifieds: Want To Buy 2 09 Jun 2007 11:44 am
