Turbo engine surging acting like its going to cut off
Old 20 Mar 2014, 07:39 pm
Default Turbo engine surging acting like its going to cut off
I have a 2004 PT cruiser turbo limited edition. I have recently replaced the turbo and numerous censors. Car runs great but when stopped at a stop light it acts like the car is going to cut off. Also sometimes if you get into the turbo hard it makes a popping noise on the right side. The code it is throwing says the turbo is over boosting. I've also replaced the idle control valve. Ideas about why this is happening? Its almost like the car surges and sputters when sitting at a stop sign or light. Ideas? Thanks!
Old 21 Mar 2014, 08:20 pm
Default Re: Turbo engine surging acting like its going to cut off
All these things happened after the turbo was replaced?
A popping noise on the right side when going wide open throttle? Might want to make a video of this noise.
How many pounds of boost are you running?
How many miles on your car?
Check fuel pressure at idle?
How old are spark plugs, plug wires and PCV valve?
Start the car up and jiggle the TPS (throttle position sensor) wires. Might need a TPS repair kit.
1999 Dodge Neon Coupe. DOHC 5 speed
2005 Crossfire SRT-6
2005 PT Cruiser GT 5 speed. 1 of 21 (SOLD)
Surging idle 2003 turbo ricketts Welcome New PT Cruiser Members 0 13 Apr 2013 05:30 pm
Repair or Replace Turbo Engine-Non Turbo? Ikster General Turbo Discussions 17 07 Feb 2012 12:28 pm
Engine surging at 4000 RPMs along with shaking at 2000 RPMs... brian5060 Tech & Performance Forum 3 24 Jul 2010 07:42 pm
oil film in intake, engine surging ptbooga General PT Cruiser Discussions 3 17 Aug 2005 05:20 pm
