2005 turbo 2.4L vibrates when at a red light
Like Tree2Likes
Old 11 Apr 2014, 03:42 pm
Default 2005 turbo 2.4L vibrates when at a red light
About a month or so I had vibration when I stop for a light or traffic (with the air on its worse).
Its a 2005 turbo 2.4L 64,000 miles In the last 2 weeks I had a machine clean the engine, a new cover, new sparks and wires and then a timing belt and water pump. Its not better. I have to return in a week to see if its better. Wen they chexked the timeing it went from 5 deg to 2.5 deg ( I think its the deg error they checked) I love the car and want to keep it any ideas?
Old 11 Apr 2014, 04:11 pm
Default Re: 2005 turbo 2.4L vibrates when at a red light
you need a new fan $$$$$$ for turbos
Old 13 Apr 2014, 12:41 am
dougs's Avatar
Are you using hi-octane fuel?
Old 13 Apr 2014, 08:32 am
He didn't say he had a GT.
Agree w/Busa - most likely the engine fan.
Old 13 Apr 2014, 08:45 am
Handy_Cruiser's Avatar
It could also be the motor mounts. When in drive and with your foot on the brake, the engine can shift more than other times. A weak motor mount might let the engine rub the chassis somewhere and cause vibration. And using the AC may increase RPM at idle, thus increases the vibration.
Check the fan first, since members with turbo PT's have suggested it. But next, I'd check the mounts.
Old 13 Apr 2014, 09:12 am
2step's Avatar
Fan? Wut??? No.
I'll bet money it's the torque struts (sometimes called motor mounts).
Old 13 Apr 2014, 09:54 am
InfernoGT's Avatar
Originally Posted by 2step View Post
Fan? Wut??? No.
Thanks for chiming in, I was scratching my head trying to figure out how the fan could cause that much vibration. When I put in my motor mount inserts, I got more vibrations at idle, but it was fine because in my mind, it was a race car
2006 PTGT with 5spd. ~60k miles
Old 13 Apr 2014, 10:49 am
Ray_Dockrey's Avatar
I am taking it you have never been in a Cruiser with a failed fan. My daughter's 06 fan failed and with the AC on vibrated horribly. The AC builds excessive pressure with no cooling and puts a tremendous load on the engine.
My guess when I first read it was with Busa. The fan has failed. They only seem to make about 80,000 miles and then failure still anytime.
Old 13 Apr 2014, 12:13 pm
Easy enough to check the fan, then we'll know!
Old 13 Apr 2014, 03:19 pm
2step's Avatar
Also easy enough to check the temperature gauge and if there is steam pouring out of the hood.
Gim'me a T.... gim'mie a O.... gim'mie a R.... gim'mie a Q.... gim'mie a U.... gim'mie a E.... gim'mie a STRUT!
What's that spell?
Torque Strut!
InfernoGT likes this.
2009 pt cruiser vibrates at idle... ive read all the posts. im stumped. help! jstnmlls Tech & Performance Forum 10 03 Dec 2012 11:56 pm
2002 pt limited edition. Engine visibly vibrates. skroehr Tech & Performance Forum 2 22 Sep 2012 07:41 pm
Steering Wheel Shakes/Vibrates at 60+ MPH paulrosenthal Tech & Performance Forum 11 24 Apr 2010 04:14 pm
WTF She vibrates, Boggs down, and Squeels!! No, not my wife!!! reefscvg Southeast PT Forum 2 15 Oct 2008 08:36 pm
Hatch vibrates after system install..... dicept1 Sound and Security Forum 9 07 Jan 2005 11:11 pm
