To be brutally honest what kind of problems would that BOV cause? It is a pretty safe thing to put on. If it fails, very unlikely, then it probably would not be covered but can,t think of what it would really damage!
06 GT Auto, Cool Vanila Exterior, Presto Change O 3bl, Cargo Mat and Net, Billet Oil Cap, Yoko Avid 4Vs Tires, 03 GT Wheels, 4 Chrome Door Handle Screw Covers, MOPAR Mud Flaps, H&R Rear Sway Bar, Freedom Strut Tower Bar, Rear Door Sill Covers. |
\"If I had a diesel rig, with a big ol\' blade, courtesy would reign, arguments abate, cuz everyone would know, I\'d SQUASH \'EM LIKE A GRAAAAAPE!\" -- Heywood Banks, \"If I Had a Bulldozer\"
Would anyone that installs their own parts forget to tighten the only three scews involved in the operation? If so they should not be working on cars at all or it might fall apart out from uder them.
How can anything "so simple looking" with no moving parts cause a problem? [:I]
Ok as I am new here and I am sure I am not the only one, What is this BOV?
\'03 GT HO PT Electric Blue Pearl Coat All the bells and whistles |
I have been meaning to ask also since I am not quite sure. It does seem simple enough to install though.
Now, if I am going say 60mph and I take my foot off of the accerator, without the BOV, it is not good for the turbo? If that is the case a BOV would be a very good thing to have, right? Even for everyday driving? Sorry, just reading other posts and had my questions answered http://www.ptcruiserlinks.com/forum/...?TOPIC_ID=7510 Sounds as if I'll get one. I'm in for the long run with the Cruiser. Got it for the dogs and they should be around for another 5 to 7 years. |
ANSWER: "There is a lot of confusion over what a BOV is and what they are good for. First of all, the name "blow-off valve" is not a very good name. In fact, the Chrysler factory services manuals call it by it's real name: the "turbo bypass valve". Somehow this valve earned the name "BOV" in the turbocharged world and it has stuck. A real blow-off valve is the same thing as a "pop-off valve", which is a valve that will suddenly open and a certain pressure to maintain that pressure (kind of like a pressure regulator). To avoid this obvious confusion, while maintaining the nomenclature of the turbo world, I will refer to the turbo bypass valve as a blow-off valve, or BOV. In a way, the turbo bypass valve does work like a pop-off valve, since they will open at a certain pressure and maintain it (about 15 psi for Chrysler's valves). This may be how it earned that name, however that is not how it is used, so who knows. So in summary, turbo bypass valve = BOV on this page. On a turbo engine, the BOV is used to relieve the pressure from the turbo output when the throttle is closed. These valves are only used on engines with the blow-through turbo setup. For more information on this, see the Turbocharger Concepts page. The BOV is basically a vacuum-actuated valve that opens when sufficient vacuum is present. Vacuum is supplied by a connection on the throttle body, while the BOV inlet is connected to the turbo output hose. On 1988 or later Chrysler Turbo I and Turbo III engines, the BOV is placed inside that airbox to suppress noise and prevent the BOV from sucking in dirty air. While in boost, the valve remains closed and the turbo pumps air into the engine normally. Without the BOV, when the throttle is closed the turbo is suddenly trying to pump air against a closed throttle plate. This creates a pressure spike in the turbo output hose and sends a pressure "wave" crashing back and forth between the throttle plate and the turbo compresser blades. The pressure spike quickly slows down the turbo and the pressure wave can actually damage the turbo. On intercooled engines, this pressure wave effect is suppressed but the pressure spike still occurs. When the throttle is opened again, the turbo has to spin up again, creating turbo lag. If a BOV is present, the BOV will open as soon as the throttle is closed, releasing the pressure spike into the airbox and avoiding the pressure wave phenomena..." The installation of the BOV appears not too difficult providing you have the proper tools and patience:http://www.lake-effect-racing.com/SR...DF/BOV-Kit.pdf
Please note, YOU ALREADY HAVE A BOV on your car. The MOPAR BOV merely converts your existing BOV to one that vents the excess air into the engine bay rather than back into the pre-compression intake area.
2003 PT Turbo Deep Cranberry \'R\' Package Stock + AutoStick Came off assembly line 1/14/03 (Tuesday) between 2200 and 2300. |
Gary04GT
Thanks for the article. Printing it out as we speak. Cruisers helping Cruisers. This is what the forums are all about. That and just making friends and shooting the bull[?] |
| How to install lowering springs? | Rymanrph | Wheels, Tires, Suspension | 4 | 01 Feb 2010 01:30 pm |
| Anyone install Borla Dual exhaust? | crazie.eddie | General PT Cruiser Discussions | 16 | 10 Oct 2004 09:21 pm |
| Anyone install their own Mopar hitch receiver? | crazie.eddie | General PT Cruiser Discussions | 6 | 06 Oct 2004 10:15 pm |
| Dealer price for BOV install? | CarolinaBlue_GT | Turbo Performance | 26 | 05 Jan 2004 02:58 pm |
| Dealer Refuses to Install Stage I | Adman | Stage Turbo Kits | 7 | 13 Sep 2003 04:41 am |
