PT Cruiser Forum Car Videos
Custom Wheels
Broken front motor mount
  #11 (permalink)
Old 10 May 2004, 12:21 am
ksquared11 ksquared11 is offline
I have solved my motor mount problem. I met with Psi-Fi Motorsports to see if the turbo upgrade that they make for the SRT-4 will fit on the PT (IT WILL). They had some urethane bushing motor mounts for $150 that I had installed.
http://www.psifimotorsports.com/mount.htm
This is the top mount.
I know that my motor mount problem are now solved. I will not be breaking these. The car does have some vibration at idle but once you get going you it goes away. I did notice that the wheel hop has decreased. The install was straight forward, replacing the stock mounts perfectly. The only problem was in getting my old mounts off. The dealer must have used an impact wrench when installing the stock mounts. It took a rather large pipe on a ratchet to remove the bolts.
Thanks Mike.
  #12 (permalink)
Old 10 May 2004, 03:09 pm
98 Neon Driver 98 Neon Driver is offline
Any increase noise at speed? My car with one filled mount and 1 solid, I have a hard time keeping a conversation on the highway.
AC
If it doesn\'t fit get a hammer. If it still doesn\'t fit, get a bigger hammer. - Jesse James
  #13 (permalink)
Old 10 May 2004, 03:39 pm
Not really, the noise decreases with higher RPMs. I do have some more noise but my Mopar exhaust created far more noise than the new motor mounts.
  #14 (permalink)
Old 17 Apr 2008, 07:56 pm
ElPasoPTCruiser ElPasoPTCruiser is offline
Default Re: Broken front motor mount
I just had the same clunk and vibrations on my 2006 PT Cruiser. I only have 18K miles yet the dealer will not cover the repair under warranty because I have a small impression on the arm that the dealer claims I hit something that cause the bolt to shear. Did your dealer who covered your repair under warranty say what cause the bolt to fail? I am looking at a $1500 repair because the upper bolt also sheared.
  #15 (permalink)
Old 18 Apr 2008, 04:52 am
fastmdpt fastmdpt is offline
Holy thread resurrection batman,,, 4 years old
Kidding,, I know Keith personally,, so I can say the second time was kind of his fault,,, he was cranked around hard on the wheel and jumped on it hard.
Tom
  #16 (permalink)
Old 02 Jun 2008, 11:37 am
hoppyloop hoppyloop is offline
Send a message via MSN to hoppyloop Send a message via Yahoo to hoppyloop
Hello ksquare11 your motor mount repair covered on 7/70 DRIVETRAIN WARRANTY. That is all i have let on mine, going to call and check dealer see what they tell me.
vB code is On
Seizing front axil MyPT03 Turbo Wheels/Suspension/Handling 8 16 Aug 2008 10:23 am
Front license plate placement spicy pt Exterior & Interior Styling 39 04 May 2008 11:15 am
Please help, front end shimmy survey Boomer Tech & Performance Forum 11 28 Mar 2005 01:33 pm
correct speaker wire harness for front speakers Curruzr General PT Cruiser Discussions 4 12 Aug 2004 04:01 pm
camber alignment kit needed for front ??? boosta Turbo Wheels/Suspension/Handling 7 10 Jun 2004 11:25 am
  Home Loan | Online Loans | Debt Consolidation | Car Accident Attorney Los Angeles | Anime Downloads
