Getting the radiator fan out of my 2003 GT- video's only show non-turbo, non AT remov
Old 09 May 2014, 10:14 am
Default Getting the radiator fan out of my 2003 GT- video's only show non-turbo, non AT remov
Its not as easy as the youtube videos make it look. The 2003 has a electronic fan connector box is hanging up on the large air hose, on the left drivers side.
Also, I just got this car and it did have slight front end damage. I am stuck because, the top right ear wont clear the a/c hose at the same time the electric connection box is trying to clear the air intake hose.
1. How far does the radiator tip out in order for you to pull the fan out? I have the model that has basically 4 radiators in the front. When tipped out to pull fan out, are all of them suppose to clear the front portion of the fender?
Unless I hear back, I think I am going to remove the right fender (potentially closer due to minor front end damage) to see if I can get some more clearance - to see if i can get the radiator to tip out more, cause the ac cooler is hitting the front of the fender on the right side potentially not allowing me to tip the radiator system out as far as i should be able to.
any thoughts?
Old 09 May 2014, 10:22 am
Default Re: Getting the radiator fan out of my 2003 GT- video's only show non-turbo, non AT r
On the pictures I have in the HOW TO section it only shows the non-turbo (because that's all there was back in 2001-2002) and I took some of the front apart and the upper radiator hose. Some said they took the battery and air-intake off to slide the radiator sideways towards the drivers side. I didn't do it that way but by taking the front pieces out, the radiator tilts forward quite a bit to give more room to lift it up and out. Not sure how the turbo models do it so hope that helps.
Removing the fan and housing 01-05 PT
BTW: Welcome to the forum. When you have the time, please go to the WELCOME section of the forum and introduce yourself.
Old 09 May 2014, 10:26 am
Yes my goal is to change the radiator, but first the fan must be removed.
then i can get to the other bolts etc, with the fan in there there is not enough room for me to reach the bolts with any of the wrenches/sockets i have.
I have a slight paranoia about scraping the ac hoses and the at hoses on the sharp metal edges of the front fenders.
And yes, I am female taking on this job, I felt strong yesterday, but after over under over under pulling from all kinds of weird angles to disconnect hoses, disconnect bolts from weird angles, removing the tires, jacking it up and putting it on jack stands, today I feel like I went to a yoga class and I am sore all over.
Old 09 May 2014, 10:35 am
thanks for the welcome. I have removed the battery/box, but, the radiator fan just doesn't pull out like the video. It wont clear the 4 inch air hose at the bottom and the right top ear at the same time, there is no shifting it toward the battery. I had my husband out there pulling too. And I also do not want to ruin the 03 turbo gt fan in the process because it looks like its still in good shape.
I will take some pics this am of where I am currently. that pic was from before i started.
Old 09 May 2014, 10:42 am
Is the AC still up? If the system is down then just remove the lines. Everything bolts to the radiator. Including the intercooler. Trans cooler, AC condenser.,
Old 09 May 2014, 10:44 am
I put it all together and installed from the bottom. By removing the lower radiator support.
Old 09 May 2014, 11:23 am
I think the ac system is still functional,entact so i don't want to disconnect that right yet.
I unbolted the front part of the right fender and it released and showed me that i do have a deficit of space on the right side that is impeding my fan extraction. I have hit it with a molly (? that tool with a slide that pulls away) and have more room now. but, now i am waiting for my 19 year old to get out of bed (day off from college) so they can pull up while i pull out to get it out.
got it out, and it was an issue of space. Thankyou
Old 09 May 2014, 04:12 pm
so radiator came in fed ex truck today. and i am so confused. This radiator is suppose to fit like OEM, but, it is not. the top opening is not like the oem.
So...the OEM is two parts, my new one has the two parts together. So if I attempt to stuff this down there it would have to already have the fan attached, because there is no way of getting the fan past the upper neck.
I could return it, and buy a different one, that had the two piece neck or I could attempt to use this one, rendering it nonreturnable if it is unable to be stuffed in behind the ac condenser with the fan attached.
What is your opinion?
Old 09 May 2014, 04:37 pm
A lot depends on if you could wait till you get the right one. I wold surely want the one that's supposed to fit properly but if you need the car back ASAP then you might want to try and use the one you received.
Old 09 May 2014, 05:12 pm
I think the only ones that come with the two part top are the OEM.
hmmm
Radiator Fan Assy Replacement video vdbd08pt PT Cruiser Videos 2 02 Sep 2013 10:46 am
2003 Chrysler PT Cruiser radiator fan motor 2.4 turbo gt model $300 (over $600 new) turbogodstoyscom Classifieds: For Sale/Trade 1 23 Aug 2013 09:07 am
2003 Turbo Radiator Fan Needed a417latino Classifieds: Want To Buy 3 20 Aug 2013 03:25 pm
Radiator Fan for Turbo and Non-Turbo Question DocLS Tech & Performance Forum 5 09 Jul 2012 09:28 am
2003 Florida Car Show CREWZIN Southeast PT Forum 0 19 Aug 2003 08:48 am
